68 911 name this part please.
300 mm long pinch weld small. I only have one but I'm sure its a pair.. B pillar on rear pop out window ???. Or ?? Its not the pinch weld on the rear window for the roof lining. I have that
I can't find it anywhere on the parts list Thanks Lyndonhttp://forums.pelicanparts.com/uploa...1562490833.jpg |
it goes inside the front trunk right hand side is a hole for the hydraulic headlight adjuster to go inside.This just wraps on the edge..here...
http://img.pccreation.net/photos/201907071329445081.JPG |
On a 68 911 ??? Hydrolic headlight adjuster??
Lyndon |
no , all 911 have this hole..that is all..and if you will be in 1968 in France for example you will have the adjuster there..
Ivan |
Ok. Thanks I will have a look
Lyndon |
I think that is the edge protection for the pop-out window...
https://www.pelicanparts.com/More_Info/90154342300OEM.htm?pn=901-543-423-00-OEM&bt=Y&fs=0&SVSVSI=911M |
al.. you might be right
Ivan |
Yep rear pop out. Goes on the B pillar.
Perfect thanks. Lyndon |
| All times are GMT -8. The time now is 06:21 AM. |
