ROW '78 911 Targa
timmy2's Avatar
I don’t know the ‘87 wire colors. I avoid ‘84 and newer wiring due to all the changes they made to the wiring and connectors. On ‘83 and earlier the low beams were yellow coming from the hi/lo switch.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-08-2019, 08:07 PM
T77911S's Avatar
Originally Posted by Walter_Middie View Post
I had a similar issue with an older vehicle in that a tail light with no power going to it would light up. It was caused by a bad ground and the current flow was finding its own way back through the bulbs.
Current travel direction by convention is from 'positive' higher level to 'negative' lower level.
Backfeeding is flow of electrical energy in the reverse direction from its normal flow.
Bad ground connections can result in circuits finding alternate grounds. Double filament bulbs with a bad ground of one lamp will cause the current to find a ground through the bulb on the opposite side of the car. The bulb can light even when they should not - like when there is seemingly no power to it.
I think you know a little about electrical wiring but not enough that you should be talking about it.
current flow is negative to positive.
when I modeled transistors in electronics school we did negative to positive.
we were also taught that there are 2 theories, pos to neg and neg to pos.
also, current flow direction has NOTHING to do with what ever it is you are trying to explain.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 07-09-2019, 03:51 AM
T77911S's Avatar
I answered the OP in a PM but the wire from the turn sw changes color in a connector.
I cant see the color that well on my diagram as the ones I have really suck. but it changes to a solid color.
Old 07-09-2019, 03:53 AM
