Is there a method to polish exterior trim pieces?
Not sure what the right term would be or what to search for this.
I am redoing my 79 SC. The exterior trim pieces are in decent condition. Certainly not great and I would like them to look better. Here is a door handle and you can see the fine scratches on the surface. Wondering if there is a method to clean those up and also on the chromed window trim? Short of sending them off for a full redo or getting replacements is there some DIY technique or product I can use to freshen these up? I have zero experience with any metal polishing of any sort so any advice is appreciated. Thanks in advance!
I think that maybe I'm dreaming.. |
El Duderino
Try Mother’s or Blue Magic polish. I used both on my polished Fuchs. Mother’s worked a little better. Just make sure you read on the label what types of metals it works on.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
El Duderino
Also look at a metal polishing wheel attachment for a bench grinder if you have one.
Brew Master
Jewelers rouge and a buffing wheel.
Nick |
I just had my handles re-chromed (78 SC), they were in much worse shape than yours, think it was about $175 for the pair. Surprised your '79 has chrome handles, I though '78 was the end of them.
Also, as said above, a buffing wheel and some rouge will probably get yours looking pretty good. Looking forward to seeing your car come out of paint! ![]()
1978 SC Targa |
Is it easy to go to far and mess them up with a buffing wheel?
I am on the fence on polishing what I have or swapping all the trim over to black. Interesting thought Solamar on your thought that '78 was the last year of chrome. I have never considered that and my car is a far departure from stock configuration so I dont really care which is correct. The car had a color change already once in the past so it very likely could have had different trim added then. |
The 9 Store
If you are concerned about using a buffing wheel, It’s almost impossible to mess it up if you polish by hand.
All used parts sold as is. |
BTW Scott, I'm sorry I never sent you the fuel line photos you requested. You're probably way past that point? I haven't worked on my car in months, it's very frustrating. Always something else. Mark
1979 911SC Targa |
Thanks everyone.
BTW the previous owner reached out to me and mentioned the car is a late 78 build but a 79 model year car and indicated that is why it has the chrome trim. |
Brew Master
I used an air die grinder with a buffing wheel to do my Fuchs. The big thing is choosing the right rouge for the job.
Nick |
