Spacer Q?
What width spacer is needed to get eights under the back on an "early narrow body"? (Going w/Carerra fenders)
Thanks,
Scott
Old 03-24-2003, 05:53 AM
AES AES is offline
None with Carrera flares and 911 8s
Old 03-24-2003, 06:01 AM
The Unsettler
stomachmonkey's Avatar
Scott,
If you are putting Carrera fenders on the car you will not need a spacer.
They will fill out very nicely.
Just put 8's on my car.
My ride height is 25 inches.
Fronts: 205/55/16
Rears: 225/50/16
I think they could come out a bit more but will do that with a slightly wider tire when I burn the current set of rubber.
The car with 6 and 7's
After with the 7 and 8's
Scott
"I want my two dollars"
"Brandon Won"
Old 03-24-2003, 06:19 AM
