-   -   Tec gt200 Bin (http://forums.pelicanparts.com/porsche-911-technical-forum/1034548-tec-gt200-bin.html)
mototron 07-12-2019 11:50 AM
Tec gt200 Bin
Hello
Losing my mind setting up a tec gt200 on a 69 911 with a
3.0 ,10/1 comp , dc 40 cams , 46 mm pmo TBs, headers sport muffler
did the initial set up , car will barely idle will not accelerate
would love to get a bin file from someone that has a running 911 with
similar engine
I am not familiar with wintec4 , to large of a learning curve to fast
I am on the east end of long Island , would gladly pay for someone to come over and help educate me and set up the system
Rocco
6313797789
mototron@optonline.net
Uwon 07-13-2019 03:52 AM
If you are going out of your mind and have no one locally to help, then I would contact Richard Clewett at Clewett Engineering. He is an expert in tuning and can do so remotely with you in the car so long as your laptop can get to the internet thru your cel phone. You will learn allot and likely get you over the hump so you can finish off yourself with the fine tuning. Best couple of hundred bucks I spent years ago.
There is an Electromotive forum thru Tapatalk that you should also peruse.
Good luck.
Johan
