Light Problems- RF Fog, Side Marker, LR Brake
I am having 2 separate issues with my lights.
First issue: I had my front bumper resprayed recently. Since getting the car back, my RF fog light and RF side marker lights don't work, RF turn signal does work. I've looked up under the bumper but can't find any loose connectors. I switched the working LF side marker bulb with the right, so I know that is not the issue. All fuses appear to be good. LF fog, turn signal, and side marker lights all work. Second issue Went for a PCA drive and several people pointed out that my RR brake light was out. When I got home, I had my wife step on the brake pedal and both brake lights worked. How is this possible? Any help with these issues would be appreciated. Update: I noticed a brown connector near the battery that is not connected, but think it was from the front blower that I removed years ago.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. Last edited by rs6er; 07-14-2019 at 02:26 PM.. |
