-   -   SC Battery cables Q (http://forums.pelicanparts.com/porsche-911-technical-forum/1034787-sc-battery-cables-q.html)
Robey5 07-15-2019 06:13 PM
SC Battery cables Q
I am chipping away while enjoying the SC that was put on the road for Dad a while back.
One of the items that I have had on the list is cleaning up the frunk area with a few things: one of them being the battery cables; and battery.
I am replacing the POS battery I purchased years back to turn the engine (and use for "now") with a AGM group 48 from a dealer that sells Deka and Delco batteries.
While I am in there, I am going to put a new cleat in to actually hold the battery in place correctly, rather than use what I tried to fab-up some years back that seemed to work OK, involving a tension/belt system.
In addition to the battery hold down, I am trying to determine if I should grab some cables and top-mount terminals (plus a quick-disconnect connection point so that I do not cook the batteries between summer drives).
My question is: I've seen a number of different styles of cables and top-mount terminals; and I have seen a fair number of fellow pelicans run what appears to be a braided (flat or round) for the negative side/ground cable for the battery.
I have a 79:
What is "period correct"?
Where can I find one of these braided copper ground cables for the negative side?
Are there any advantages to running a bare copper braided wire on the ground side?
I am sure that I will be able to gain a minimum of 35.22HP as a result of using such a fancy ground cable...
tmadden2 07-15-2019 06:57 PM
You’re looking for 911 611 899 00. It looks like Pelican has gone to the insulated version, but eBay or dC Automotive will have the braided bare copper one. I can’t help with what the advantages would be of the original one.
timmy2 07-15-2019 07:10 PM
Only advantage of the braided cables is you can watch them turn black and then green as they oxidize. :)
