-   -   parallel window regulator help (http://forums.pelicanparts.com/porsche-911-technical-forum/1035337-parallel-window-regulator-help.html)
grantsmells 07-22-2019 02:18 AM
my '82 cab (with doors from who knows when) has parallel style window regulators, the motor was dead and window stuck up when i removed the motor from the regulator, so had to reach my hand up inside the door and VERY slowly remove the 3 bolts.
i managed to manually get the window halfway down, but still cant get easy access to bolt the motor back to the regulator, is there a trick to this? or do i just have to sick my hand up inside the door again and do up each bolt 1/6th of a turn at a time :(
the only info i can find is on the spider type 6 bolt regulators.
