-   -   Castrol SRF - no longer available?? (http://forums.pelicanparts.com/porsche-911-technical-forum/1035521-castrol-srf-no-longer-available.html)
VFR750 07-24-2019 08:10 AM
No one has Castrol SRF brake fluid in stock.
Summit no longer lists it
Many other say it’s out of stock.
Anyone else know what’s happened and where I can get some??
911pcars 07-24-2019 10:06 AM
Not too hard to get. Only 219,000 citations:
https://www.google.com/search?client=firefox-b-1-ab&ei=hJ04XYrxC9bz-gTBn67YCQ&q=castrol+srf&oq=castrol+srf&gs_l=psy-ab.3..0l10.2449.4911..5266...0.0..0.715.2851.4j3j0 j1j1j1j1......0....1..gws-wiz.......0i71j35i39j0i131j0i67j0i10.kwzsnNilplc&v ed=0ahUKEwiKw4mMks7jAhXWuZ4KHcGPC5sQ4dUDCAo&uact=5
VFR750 07-24-2019 12:00 PM
And when I try to place an order at the usual places I get “out of stock”
spyerx 07-24-2019 02:56 PM
Try Brembo HTC64T or Endless RF650
These are both high temp racing fluids. I prefer Brembo.
911pcars 07-24-2019 03:20 PM
Unless you're shopping price or you only buy from your favorite Porsche parts house, you're not trying hard enough.
The first link I selected from that google search page was at Amazon. They have 13 liters in stock with about 15 independent backup sources ready to ship.
Buy it but don't waste it by pressure bleeding it all out.
Sherwood
Bill Verburg 07-24-2019 03:27 PM
Here's a list, in order best to next etc, of the best b/f out there
http://forums.pelicanparts.com/uploa...1564010647.gif
For Mikes application where his brakes are highly stressed SRF is the way to go
for mine which are not stressed much, RBF 660
911pcars 07-24-2019 04:55 PM
I assume Mr. Verburg's BF chart, column 5 describes the Wet boiling temp. specs. That is, the boiling point of that BF with a given % of moisture.
That is the more important spec to understand since all BF attracts moisture once out of the can.
Sherwood
VFR750 07-25-2019 02:22 AM
Yes. Wet boiling point is the driver. SRF is the best
I have looked at my favorite sites for SRF. (Pelican does not sell it)
Pegasus, summit, jegs, og racing. They don’t have it in stock and jegs says it will ship from castrol in October. Hence my op
Chilling in VT 07-25-2019 04:06 PM
I bought a quart out at the little shop at the end of the garages when we were out at Watkins Glen last month. They had quite a few bottles on the shelf. You might want to give them a ring.
naro914 01-29-2020 12:23 PM
I just ran across this thread - not sure if you guys were able to get the SRF when it became available again? or if you still need any? we have 8 bottles left at the moment.
https://naroescapemotorsports.com/product/castrol-react-srf-brake-fluid/
911pcars 01-29-2020 02:10 PM
Seems to be available:
https://www.google.com/search?safe=active&sxsrf=ACYBGNRU6LnteR5BF3fbm5LLK RANmba8ng%3A1580339351476&source=hp&ei=lxAyXpedGuy x0PEPy_ijuA4&q=castrol+srf+brake+fluid&oq=castrol+ srf+brake+fluid&gs_l=psy-ab.3..0l9j0i22i30.2375.7279..7500...2.0..0.195.181 6.22j1....2..0....1..gws-wiz.....10..35i362i39j0i131j35i39j0i10.F6sgWIx1lYU &ved=0ahUKEwjXxKrt9qnnAhXsGDQIHUv8COcQ4dUDCAc&uact =5
Solamar 01-29-2020 04:54 PM
Just for fun I looked up Napa DOT 3 brake fluid wet boil, 284*f.
Well below the bottom of the list above...
naro914 01-29-2020 05:02 PM
But go to most and they say “backordered” or not available.
Summit, Pegasus, OGRacing, Discovery are all out. We have a local Nascar huge supplier that keeps a few cases always available for us.
I just ordered another 2 cases today.
Customer of ours ordered from Amazon when we were out in October...it never showed up.
Driven97 01-30-2020 03:48 AM
Wow ATE Typ200 (used to be able to get in blue also for easy bleeding) is 536°/388° and also wouldn't make that list.
Quick question, do these hyper fluids have decent life or do you have to change / re-bleed often?
VFR750 01-30-2020 04:46 AM
Depends on what you are doing. Street? Don’t bother with the high end stuff. Trackday? I bleed after every event and flush at least twice a season. Racing? Probably flush after each race weekend would be my guess.
Driven97 01-30-2020 04:49 AM
I guess I'm asking for those who use the car on the street but do 1 or 2 track days a year. Do the fancy fluids make poor street fluids for any reason.
Jonny042 01-30-2020 05:53 AM
Unless you're brakes are marginal for the application (not likely if you ask me, on a 911, the brakes are huge) the maintenance of the fluid is more important than the brand, assuming it's half decent to begin with.
When I was racing IT, which required stock brakes, I used Wilwood fluid. I changed it a couple times a year. For the odd track day you'd probably be wise to freshen in the spring.
Here's a little quote from Wilwood. I found the point about the DOT 5 fluid interesting.
Due to the extreme operating temperatures of a high-performance brake system, standard off-the-shelf brake fluids are not recommended. Of critical importance in determining a fluids ability to handle high temperature applications is the Dry Boiling Point and compressibility.
The Dry Boiling Point is the temperature at which a brake fluid will boil in its virgin non-contaminated state. The highest temperature Dry Boiling Point available in a DOT 3 fluid is 572 degrees F.
The Wet Boiling Point is the temperature a brake fluid will boil after it has been fully saturated with moisture. The DOT 3 requirement for wet boiling point is a minimum temperature of 284 degrees F.
There are many ways for moisture to enter your brake system. Condensation from regular use, washing the vehicle and humidity are the most common, with little hope of prevention. Glycol based DOT 3 & 4 fluids are hygroscopic; they absorb brake system moisture, and over time the boiling point is gradually reduced.
Wilwood does not recommend using DOT 5 fluid in any racing applications. DOT 5 fluid is not hygroscopic, so as moisture enters the system, it is not absorbed by the fluid, and results in beads of moisture moving through the brake line, collecting in the calipers. It is not uncommon to have caliper temperatures exceed 200 degrees F, and at 212 degrees F, this collected moisture will boil causing vapor lock and system failure. Additionally, DOT 5 fluid is highly compressible due to aeration and foaming under normal braking conditions, providing a spongy brake feel.
Whenever you add fresh fluid to your existing system (never mix fluids of different DOT classifications), it immediately becomes contaminated, lowering the boiling point of the new fluid. For maximum performance, start with the highest Dry Boiling Point available (try Wilwood Hi-Temp 570 Racing Brake Fluid), flush the system completely, and flush it regularly, especially after severe temperatures have been experienced.
Matt, I really enjoyed your blog about Autocrossing the Carrera, thanks so much for documenting that - I ended up following your example and widening the front Euromeisters on my car to 8" to suit 225 front tires. The car is FAST! The re-geared transmission is the biggest contributing factor. I do need to address the damper situation when I have time. Currently running 21/28 TB's and Eibach sways and HD front/Sport Bilsteins. Here's a quick vid. Room for lots of improvement, this year will bring a TBD diff and a quick steering rack and maybe a revalve of the shocks, and maybe 29mm rear TB's...... seems a little soft.
<iframe width="560" height="315" src="https://www.youtube.com/embed/SgnEv8kwUnY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Have you documented the track-day experience at all on the blog? I've thought of doing some track days in the Rot Rod and would love to hear how you've made out.
VFR750 01-30-2020 08:21 AM
The higher temperature capable fluids DOT4 are just fine for the street. I use them year round.
Some, fluid like the Motul 600 seem to be a little bit mushy, even when new. This makes the pedal feels softer than a stock fluid.
My observation is SRF seems to be less compressible.
Thats probably the only trade off, depending on the fluid.
911pcars 01-30-2020 09:22 AM
Just a reminder. Any liquid in an enclosed system cannot be compressed unless air is introduced or caused by heat hot enough to boil (vaporize) it.
Caveat (CMA):
https://www.physlink.com/education/askexperts/ae15.cfm
Sherwood
WP0ZZZ 01-30-2020 09:59 AM
Caveat (CMA):
Sherwood
The bulk modulus of a liquid is the physical property that tells us how much a liquid will compress when subjected to pressure:
https://en.wikipedia.org/wiki/Bulk_modulus
