Time Traveler
Can I put a 944 steering wheel on a Carrera 3.2?
Can I put a 944 steering wheel (944.347.084.08) on a 1988 Carrera 3.2?
To my eyes, they look the same, but I dont know.
I prefer text 504.722.3857
The splines are different, so, no
Bruce |
Wheel doesn't matter. Hub does. I believe they have slightly different spline counts.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Time Traveler
Does anyone have a part number for the Carrera 3.2 steering wheel?
Will try to grab mine later. I replaced the stock with a 968CS wheel, but it was specifically mounted to a hub for 911 use.
per the PET, for 87-89 the steering wheel part number would have been: 911-347-084-08 380mm sport steering wheel or 911-347-084-09 380mm sport steering wheel with elevated hub. |
Afaik, the early 944 wheel (pre-dash facelift) uses the same splines, so yes on those.
