Bosch Alternator
Thanks to everyone who has helped with input
Found a Rebuilt Bosch 70 amp alternator with external voltage regulator for my 74 911. The original alternator in the car was a lower 55 amp SEV Marchal with external voltage regulator. Any problems in using this higher amp bosch unit?
Old 07-25-2019, 02:34 PM
76 911S Targa
It is helpful to those who may follow in your footsteps to keep everything in one thread. You have two other threads on this topic. Those other threads will leave readers confused until you post this final message. Inquiring minds want to know what finally happened. I am glad you found a replacement alternator.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 07-25-2019, 03:12 PM
