Perpetual Reassembler
2jmotorsports's Avatar
CIS Fuel Adjustment Hex Wrench Length
Does anyone have a factory CIS fuel adjustment hex wrench?
If so can it be maneuvered in the small space between the fuel distributor/air flow meter and the top of the firewall?
If it can how long is it approximately?
This replacement one I purchased a while back is way too long (6 inches) and Im going to have to cut it down but Id rather cut it once than sneak up on it with 30 hits on the bench grinder.
Thanks in advance.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 07-27-2019, 10:50 PM
Size of allen wrench for CIS Fuel Adjustment??
Not sure it works well with the metal fuel lines. I use a 3mm allen wrench that doesnt have the large metal loop at the top that the official tool had.
Old 07-28-2019, 03:16 AM
The long 3 mm Allen in any set will do the job
You don’t want to turn it very far either way
On an 83 you need to disconnect the ox sensor to adjust enrichment.
Bruce
Old 07-28-2019, 03:58 AM
proporsche's Avatar
the original tool to set the c/o is made by Stahlwille company..like this one..on top
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-28-2019, 04:38 AM
Functionista
manbridge 74's Avatar
Nice picture. OP can use it as a scale to cut down tool if he still has the plug (missing on a lot of cars).
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-28-2019, 07:06 AM
47silver's Avatar
I found my plug on the fan shroud behind the filter housing when i was working on it. Seems to be an easy place to lose it
Old 07-28-2019, 07:28 AM
proporsche's Avatar
here is a detail.....for manufacturing use
cis adjustment tool
I thought this might be of some help.
I have a 1982 SC with the metal fuel distributor lines. I was having difficulty with the handles of adjustment tools contacting the fuel lines so I made the two homemade tools in the attached pictures that slide down within the fuel lines and work very well.
the white one is made from a pvc hollow plug - I inserted the Hex tool and then filled the cavity with JB weld. The yellow ones is a wire nut filled with JB weld with a hole drilled for a cut off nail to be inserted. The white one id made with a "ball" end hex that make it a lot easier to insert. Total length of handle and hex is 4.5 " for the white one and 4.75" for the yellow one.
Anyway, these work great for me so perhaps this might help someone.
Dave
Old 07-28-2019, 07:36 AM
Thanks for the feedback everyone. Ill see what I can figure out with my current wrench or with another one.
Bruce
Thanks for this tidbit Bruce, O2 sensor will be disconnected beforehand.
Old 07-28-2019, 08:54 AM
Just to close the loop on this. The T-handle tool is way too long. I ended up using a long 3mm allen wrench and it worked like a charm.
Also, there is very little clearance with the metal fuel lines in the way such that the T-handle one wont work even if its the right length. I will likely cut it shorter to 10.5cm like the factory tool in the linked thread, and cut the T-handle so it looks more like a letter P. The only advantage to that over a standard wrench is a bit more leverage when turning with your fingers.
Thanks again everyone.
Old 07-28-2019, 09:06 PM
I am my 911's PO
'78 SC's Avatar
I also found the T-handle interfered with getting the tool in and out. I cut it down as you described and added some red shrink tubing for visibility.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 07-29-2019, 06:59 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
I did this adjustment yesterday. The t-handled allen wrench that I bought specifically for this job was useless. To make it work would have required the same mods you see here- cut it short (~10cm) and remove one of the ears.
Turns out that my regular 3mm allen wrench with a ball end was the perfect tool. You don't need much leverage (at least I didn't) and you don't want the handle very long because there isn't much space to get it in and there isn't much space to turn it.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 07-30-2019, 03:12 AM
