No electrical power at all
On my ride home today my 88 911 died in traffic. I have had the car for about 2 months, and I am a new 911 owner. I heard a pop, the battery light flashed once, and the whole harness went dead. The car was running great right up until it died, then no lights, no ignition, dead. I had the car towed home, and it is now safely in the garage.
Obviously I need to find the bad component. Does the 88 911 have a fusible link? I couldn't find anything with search. Any ideas or suggestions to point a newbie in the right direction would be appreciated. Is this the DME failure I keep reading about? Thanks - Scott |
Are you saying that there are no dash lights, car won't spin over? If so, battery terminal issue probably. Also 2-3 power wires that attach to the positive cable can get loose. If the battery isn't bolted down it puts a strain on the cable connections. Bob
start with the basics..connection on battery mainly the ground than report back...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks - The main ground was the culprit. Cleaned the terminals and connection to the frame and all is good. Also added a headlight relay while I was in there.
good job;-)
