1973 fuel lines
Hello: Is there a second return line to the gas tank from the rear? Or did excess fuel get recycled back through the pump? I am not seeing a return line underneath, and there was a "Tee" that brought excess gas back to the pump. Now I am installing a Facet pump. If there is a second return line, I'll use it. Otherwise, I'll blank off the return line in the rear and go with one line.
Thanks for reading.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 07-29-2019, 04:47 PM
Does your car have MFI with the fuel pump in the left rear above the torsion tube? If so there is a return line, part #911-356-064-05-OEM, from our host. It connects to the pump, the fuel filter in the engine compartment, and the fuel return line in the tunnel. I don't think it will work with a Facet pump, however.
Dave
1969 911T Coupe
1972 911E Targa
Old 07-29-2019, 06:40 PM
