Odd 964 Rear Seat Retention Bolt Rusting?
Good evening Pelican Braintrust,
I am considering purchasing a 1990 C4 and the rear seat retention bolts are severely rusted.
I would welcome comments, reasons and if this is a common issue?
I don't think I've read a thread on this before?
Old 07-29-2019, 08:04 PM
Unscrew them, clean and paint?
206 637 4071
Old 07-29-2019, 08:42 PM
Ctopher's Avatar
Actually that’s interesting as I have similar rust on my 87 Carrera coupe rear seats. I have not removed and/or investigated further. Would water from rear window leaking cause this? What about water on the rear shelf? Something to think about and maybe investigate. I need to do the same.
CTopher
Old 07-29-2019, 08:46 PM
These bolts for some reason seem to rust very easily.
That said, it is from moisture, i.e. water ingress. Look for other signs, esp. in the seat pans.
Old 07-30-2019, 03:16 AM
Flojo's Avatar
poor coating back in the days, humidity in air, the years passed… rusty.
retrieve, blast, coat, done, get out and drive :-)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
https://www.instagram.com/spadescustomz_/
https://www.instagram.com/911garage_germany/
https://www.facebook.com/911garage
Old 07-30-2019, 03:20 AM
Agree with Flojo. If that’s the worst rust on the car, be very happy!
Old 07-30-2019, 01:19 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Beware!
Water in that area could be from a leaking window seal. Look very closely at the seat pans. Zinc/Cad plating is sacrificial. When it is gone, the steel will begin to corrode(rust). My question is what else is rusting?
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 07-30-2019, 02:27 PM
Titanium User
Those bolts are also likely seized. They're very hard to remove in my experience even without showing rust.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 07-31-2019, 04:00 AM
Originally Posted by Ctopher View Post
Actually thats interesting as I have similar rust on my 87 Carrera coupe rear seats. I have not removed and/or investigated further. Would water from rear window leaking cause this? What about water on the rear shelf? Something to think about and maybe investigate. I need to do the same.
CTopher
Id pull your carpet and further investigate. Most of us rarely use or acknowledge the rear seats so a leak can go unnoticed for some time.
Since the OP is looking to purchase he may not be able to pull back the carpet on the subject car. It is hard to tell from the photos, but it looks like there is glue visible at the edges of some of the carpet pieces which may indicate repeated wet and dry cycles. This could be due to regular wear and tear, but again these areas typically see very little traffic.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 07-31-2019, 06:12 AM
If you can, pull the carpets and look for moisture. I was lucky, I removed everything in the back to prepare for an RS carpet kit. The carpet was wet and the rear seat pads were wet and "mushy" Both seat pans must have stayed wet enough to go through the coating with one side rusting through. I wonder if I bought the car with wet carpets and it just never dried out? Car did smell a little funky but I thought that was Porsche smell!
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2017 VW Golf TSI
Old 07-31-2019, 08:08 AM
My 1990 C2 had water ingress into the rear seat area a few years back. I thought it was coming from the rear window seal, but it turned out to be plugged sun roof drains.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 07-31-2019, 08:13 AM
cycling has-been
bkreigsr's Avatar
I use a big Craftsman screwdriver (16.5" total length) and a 3/8ths open-end wrench on the shaft. Couple of over night soaks also helps.
If you screw this up, the alternative is a to drill out the screw. - very messy.
Bill K
Old 07-31-2019, 10:30 AM
Bill Douglas's Avatar
If you want to reuse the bolts a quick and nasty way to refinish them is to clean them up with a wire brush etc. Then heat them up with a gas torch and dip them in any old oil. It makes them a LOT more rust resistant and a cool black colour.
see www.lyallbaybeach.co.nz
Old 07-31-2019, 11:05 AM
kuba_kuba's Avatar
My '88 had the same thing. Dry car, no rust, no leaks (well it's a targa so there are leaks but not in that area). A big screwdriver, patience and overnight soaks will get them out.
'88 911 Targa
Old 08-01-2019, 05:51 PM
This may very well be the case, but Id check anyway.
Old 08-01-2019, 06:02 PM
