Oil cooler help -- Chuck M. or others....
Yesterday I bent the lower right half of my front mounted oil cooler on my '71E -- there is a hairline crack which isn't very visible in the picture... The tire was rubbing against it when turned to the left. I pushed the cooler back in place and at least it isn't rubbing anymore.
Fortunately the weather has not been hot enough that the thermostat has triggered the external oil cooler circuit.
What should I do now? Can I have it welded, or does it need to be replaced? If so, Chuck, do you have another one you can send me? Thanks, Evren
Old 03-30-2003, 08:25 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I m ay be wrong, but that is the stone guard and it did it's job. The Carerra cooler is behind it and a crack in the stone guard will not harm anything...then again I have a Mocal and a fabricated stone guard and have never worked with the factory coolers other than trombone.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 03-30-2003, 08:47 AM
pwd72s's Avatar
Evren, in case you check here before reading your mail, H.D. nailed it. The shield did it's job. The cooler always holds some oil, so if you'd holed the cooler itself, you'd have known it.
Old 03-30-2003, 11:03 AM
thanks HD! I guess that was close... hope your 3.6 conversion is going well.
Paul, I've sent you the details of the oil temp gauge...
Old 03-30-2003, 11:39 AM
pwd72s's Avatar
Hmmm, that's funny...I see your post, but no mail yet. Pelican must be like Porsches...just faster!
Old 03-30-2003, 11:41 AM
Send a message via Yahoo to tmctguer
ditto.........what is dented is merely the oil cooler COVER. behind it, sits the oil cooler which undoubtedly received no damage.
Old 03-30-2003, 01:01 PM
Montana 911
k9handler's Avatar
no problem...how is Turkey? I was sitting here thinking of how good the chicken tava is....mmmmmm!
H.D. Smith
2020 Yamaha YFZ450R
Old 03-30-2003, 05:31 PM
Buy them, sell them
Adam's Avatar
Evren, how did you damage it? Did the wheel hit it during a moment of suspension compression (bottoming out), or did you pick up some road debris?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 03-30-2003, 05:39 PM
Nope, it was a very low impact incident -- we were barely moving. My cousin and I were about to park and pulled up by the side of the road. I guess the curb was higher than it looked and there was a scraping noise. The lower right corner of the cooler & cover was pushed back, so we shoved it back in until it snapped into place...
Old 03-31-2003, 12:51 AM
