Rear Fog Light (SC) - mounting details?
Hi Folks:
I am planning to add a rear fog light to my 78 SC (Japanese spec car). Although I know that this car did not have this option, I really like the look and also like the safety feature as well. I have purchased the parts from Pelican including the correct bracket and light.
My question:
Can someone kindly post a picture of a factory installed foglight with dimensions to show exactly where the three holes are drilled in the rear valence? I would like to mount the light in exactly the correct place that the factory did.
Also any as installed pictures for a factory installed rear fog light would be appreciated.
Thanks very much.
Karl
Old 07-29-2019, 06:08 AM
speednme1's Avatar
Some cars have the original wiring in place(though they weren’t specced with a rear fog light). Check under your left rear wheel. The factory wiring is folded into the wiring insulation also the factory wiring for the switch will be under the middle of the dash. The fresh air box will need removal to get to the wiring under the dash. One of the factory wires (under dash wires) goes to the head light switch. There is an open terminal where it goes. So to summarize, if you have the factory wiring under the left rear wheel you will have the wiring under the dash. Search pelican , there are some threads with photos.
Rey....77 930 "the Mistress"
Old 07-29-2019, 06:54 AM
4flyboy's Avatar
Hey Karl,
This will help:
Can I wire Rear Fog to Front Fogs w/out frying my system?
Euro Rear Fog Light
I will take a pic of the install on my M491 though it isn't factory it's in the correct spot....
Good luck
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 07-29-2019, 07:13 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
The switch in the dash needs to be like rear window/mirror defroster. My '84 fog light switch was the on/off 2 position with no twist like the defog switch. I replaced it with a defog switch from eBay. The wire is coiled up behind the air distribution box and left rear wheel tied to the wiring. More tedious than anything else.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 07-29-2019, 09:40 AM
Thanks for the tips. I will check for the wiring over the next few days when i get a chance. And i would appreciate a few pics - thanks!
Karl
Old 07-30-2019, 08:08 AM
The factory shop manual has specs for where to drill the holes. Made a template out of paper which worked out well. Will post a pic of the page later tonight..
Old 07-30-2019, 09:06 AM
Thanks Mark. Template is a great idea. Pics as well please?
Old 07-31-2019, 05:27 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
I did mine a different way, but there are pictures and lots of information about switches, etc. that will absolutely apply to what you're doing.
Rear fog light install- a new approach, some help needed
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 07-31-2019, 01:33 PM
here are the measurements
Old 08-01-2019, 07:18 AM
Thanks Mark. A big help.
Karl
Old 08-02-2019, 07:33 AM
