Oil leak from exhaust header and lots of smoke
Hi Guys,
'82 SC.
The car had been sitting for a little over a month and this morning I was greeted with this oil puddle. When I parked the car it ran great no smoke, good power, runs just fine.
I had a poke around underneath and found this. It looks like it's coming from the number 3 exhaust header ... there's quite a bit of oil. The feeling in my stomach is not good right now. Yes my heat exchanges are toast.
I started it and let it run for about a minute. It smoked like crazy from the exhaust. This was to be expected obviously but it was getting worse so I switched her off. The motor sounded to be running just fine. I think I killed every mosquito in my neighborhood.
What do you all think am I dealing with here? Some kind of blown seal (rocker shaft?) or something more serious like an oil ring or valve guide failure?
Thanks,
G.
Old 08-03-2019, 04:03 PM
Still here
pmax's Avatar
I think you need to drive her more.
Old 08-03-2019, 05:09 PM
^ Agreed
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 08-03-2019, 05:20 PM
Geez I hope you are right! Oil just leaking past seals? So just drive it until the smoke stops?
Old 08-03-2019, 05:46 PM
At night😉
Old 08-03-2019, 09:49 PM
Ha yes will do! Good idea.
Old 08-04-2019, 06:43 PM
