7783911's Avatar
yellowbox speedo ratio adjustment
after reading several posts I decided to try the YellowBox ratio adjustment unit. 75% of the time its spot on now compared to GPS but on occasion it will oscillate wildly then return to correct speed. Bad BOX or should i be looking elsewhere...prior to yellowbox, the speedo never oscillated but was reading 10% off and the ratio box corrected that except for these aberations
any ideas out there?
Old 08-03-2019, 02:37 PM
Hmm. Actually, I had an issue when I first fitted the Yellow Box; which is why I never posted the traditional triumphant installation post with pictures that I'd expected to...
Specifically, what I saw was that the indicated speed reading would abruptly drop ~8 MPH, stay there for like 1/4 of a second or so and then return almost immediately to the previously-indicated speed - but it'd overshoot it and sink back down to the "correct" reading. And some seconds (maybe 10-15?) it'd do it again.
I removed the Yellow Box - and noticed that without it fitted, the speedo did the same thing with about the same frequency, although not as pronounced; more like 3-4 MPH drop - which actually just looked more like a "tremble" in indicated speed when driving along than the "drop-and-kick". Not as noticeable.
I bought a pocket DSO, aiming to trace the input/output of the YB to track down the source of the anomaly - but got distracted. I also try not to spend time staring at the speedo in normal driving, and having it indicating correct speed >99% of the time was still a win.
One day, somewhere between 6 months to a year after fitting the YB, the speedo that was fitted (not the original, as the odo stopped on that @ 247K miles) just stopped working. Zip, nada, zilch etc.
I fitted a random used (and maybe repaired) 3.2 speedo I had picked up years earlier - and it worked perfectly. No jumping at all.
"Oh, sweet..."
Some years before this, I had had a voltage regulator fail. Which I only noticed because the fuzzy growth on the negative battery terminal was insane (clean it off and it'd come back in less than a week). Yeh - battery was boiling; 18V across the terminals at idle. Never a moment's instability or weirdness with the tach BTW...
Replaced alternator (and thus the built-in VR), thought no more of it.
Comparatively recently, I was reading a thread here and found mention of components in the speedo rated at 15V or 16V. Which is fine on a 12V car - until your VR starts kicking out 18V on a prolonged basis...
So concluded that over-voltage had probably damaged the speedo, but that it still mostly worked. Until one day it didn't.
Don't know why the YB seemed to make the damaged speedo more sensitive - but the replacement is still soldiering on without issues a decade later, sooo....
'77 S with '78 930 power and a few other things.
Last edited by spuggy; 08-03-2019 at 05:42 PM.. Reason: clarify symptom description
Old 08-03-2019, 05:32 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Yellow box is sensitive to overvoltage. My car spit out a short term overvoltage of 17+ volts for a few moments. Yellow box failed shortly thereafter. I have a post on the adventure.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-04-2019, 09:23 AM
Wouldn't surprise me. The Yellow Box can use either a 5V or 12V supply. Perhaps a little isolation (eg stepping down 12V->5V) would protect these better. Something intended to step 12V down for USB power should do the trick nicely.
My overvoltage happened & was completely rectified some time before the YB came along. Pretty sure that damaged the speedo itself - even though it seemed to continue to work - given that when I looked closer, I saw erratic behavior without the YB in circuit. But it was less pronounced/obvious so I'd never really noticed it before. The speedo I fitted after wasn't erratic at all, with or without the YB.
Early_S_Man (RIP Warren) sums it up succinctly in this post Carrera VDO Speedo SUCKS., where he says:
Originally Posted by Early_S_Man View Post
Actually, the same component [input filter cap] Paul found bad ... is well known for failing in all of the VDO speedos [Volvos, BMW, Mercedes, Audis, Ford, Nissan] using the UAF2115 chip. It is a bit marginal, at best, with the 16 Volt rating, so I would recommend replacing it with a 100 uF 50 Volt cap ... like this one:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=29963&pa=29963PS
It would seem that failing alternators that are boiling batteries with 16+ Volts output are also frying that marginally-rated capacitor ... and the indication of a pending failure is a jumping, or erratic speedometer needle!
There are two 16V caps in the speedo. These threads: Sewer backs up, and speedo smokes. Carrera VDO Speedo SUCKS.
The 100uF can short internally when it fails - which leads to the 33 Ohm resistor burning out (usually badly enough it can't be identified from the color bands).
For example, this thread: Help !! My Speedo Fried :(.
The conclusion:
Originally Posted by drola View Post
i went to radio shack. bought a 47 & 100 50v caps and a 33 ohm resistor.
speedo works like new.
Cost - less than $5 including tax
Thanks again !
Old 08-04-2019, 11:07 AM
