yellowbox speedo ratio adjustment
after reading several posts I decided to try the YellowBox ratio adjustment unit. 75% of the time its spot on now compared to GPS but on occasion it will oscillate wildly then return to correct speed. Bad BOX or should i be looking elsewhere...prior to yellowbox, the speedo never oscillated but was reading 10% off and the ratio box corrected that except for these aberations
any ideas out there? |
Specifically, what I saw was that the indicated speed reading would abruptly drop ~8 MPH, stay there for like 1/4 of a second or so and then return almost immediately to the previously-indicated speed - but it'd overshoot it and sink back down to the "correct" reading. And some seconds (maybe 10-15?) it'd do it again. I removed the Yellow Box - and noticed that without it fitted, the speedo did the same thing with about the same frequency, although not as pronounced; more like 3-4 MPH drop - which actually just looked more like a "tremble" in indicated speed when driving along than the "drop-and-kick". Not as noticeable. I bought a pocket DSO, aiming to trace the input/output of the YB to track down the source of the anomaly - but got distracted. I also try not to spend time staring at the speedo in normal driving, and having it indicating correct speed >99% of the time was still a win. One day, somewhere between 6 months to a year after fitting the YB, the speedo that was fitted (not the original, as the odo stopped on that @ 247K miles) just stopped working. Zip, nada, zilch etc. I fitted a random used (and maybe repaired) 3.2 speedo I had picked up years earlier - and it worked perfectly. No jumping at all. "Oh, sweet..." Some years before this, I had had a voltage regulator fail. Which I only noticed because the fuzzy growth on the negative battery terminal was insane (clean it off and it'd come back in less than a week). Yeh - battery was boiling; 18V across the terminals at idle. Never a moment's instability or weirdness with the tach BTW... Replaced alternator (and thus the built-in VR), thought no more of it. Comparatively recently, I was reading a thread here and found mention of components in the speedo rated at 15V or 16V. Which is fine on a 12V car - until your VR starts kicking out 18V on a prolonged basis... So concluded that over-voltage had probably damaged the speedo, but that it still mostly worked. Until one day it didn't. Don't know why the YB seemed to make the damaged speedo more sensitive - but the replacement is still soldiering on without issues a decade later, sooo....
'77 S with '78 930 power and a few other things. Last edited by spuggy; 08-03-2019 at 05:42 PM.. Reason: clarify symptom description |
Caveman Hammer Mechanic
Yellow box is sensitive to overvoltage. My car spit out a short term overvoltage of 17+ volts for a few moments. Yellow box failed shortly thereafter. I have a post on the adventure.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
My overvoltage happened & was completely rectified some time before the YB came along. Pretty sure that damaged the speedo itself - even though it seemed to continue to work - given that when I looked closer, I saw erratic behavior without the YB in circuit. But it was less pronounced/obvious so I'd never really noticed it before. The speedo I fitted after wasn't erratic at all, with or without the YB. Early_S_Man (RIP Warren) sums it up succinctly in this post Carrera VDO Speedo SUCKS., where he says: Quote:
The 100uF can short internally when it fails - which leads to the 33 Ohm resistor burning out (usually badly enough it can't be identified from the color bands). For example, this thread: Help !! My Speedo Fried :(. The conclusion:
'77 S with '78 930 power and a few other things. |
