my take on 911r / R Gruppe lightweight hot rod
Figured I was far enough along to finally start a thread on this build. Most of the 911 guys might not know me as I have not posted much in here.
Here is a picture of my backdated 930 I just finished ![]() ![]() So this all started when my buddy Brendon (IMR_Merlin) came to visit me for Turbopalooza last year. After consuming my first bottle of Kettle, I somehow agreed to purchase a 1979sc from him that was sitting around for quite some time. My plan was the purchase a airline ticket from NJ to Boston, then drive the car home 7.5 hours. Now, driving a car home 7.5 hours that has not been on the road for 10+ years was not the smartest idea, but I figured if it made it, then I had purchased a decent car, if not, it would make for one hell of a story Here is what I started with ![]() ![]() This car made it home 7.5 hours, with not a drop of oil on the motor, zero smoke, and zero hesitation... My goal is to build a 2200-2300 pound car with roughly 200hp |
First day of tear down and found this little guy right up by the steering wheel
![]() I have torn down about 5 of these cars now, and I have to say, this was by far the worse. Every single nut and bolt fought me till the end ![]() first thing was to get the new latch panel in ![]() ![]()
test fit
![]() and were in! ![]()
Next thing that showed up was my full Carbon Roof from Helion, This thing was amazing!
![]() I can not believe how freaking heavy the sunroof is ![]() ![]() so its gotta go
Okay, back to the front for a minute. I decided to remove the impact bumper mounts, 1. cause they are heavy, 2. there was some rust I wanted to tackle up there.
drivers side was a lot harder with the curves
so, this was not on my list of **** to do, but after removing the rubber sill, rust, paint, and body filler came with it! I should have peeled the other way
quarter panels were a mess, so off they came. Decided to go with full fiber quarters. I was pleasantly surprised at how well these fit
Fantastic work there!
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
back to the motor. I thought long and hard, but I figured after driving 7.5 hours and not leaking a single drop of oil or smoke, perfect compression and leakdown numbers, just to leave the big port 3.0 longblock alone.
housing and fan back from powder coat
![]() EB Motorsports Shroud
While motor is out, I decided to replace as many seals as possible and that I could access. I also replaced all the oil lines and hardware
![]() ![]() I made the decision to run a port matched Jenvey ITB EFI set up and these things are amazing! ![]()
never made any AN lines before, but its not as hard as I thought it was
Nice work, Jim !
WOW! You saved that car. Amazing job - more pics of the finished care PLEASE!
Chris '75 911s 3.2 - Ice Green Metallic ‘87 951, '05 987 S '21 Jeep Gladiator ‘18 Tesla ModelX 100D, ‘20 Model 3 |
I did not have any problems what so ever shifting, but figured while it was out, why not go through it!
![]() ![]() ![]() Cant be lightweight without RSR lightweight pressure plate and flywheel ![]()
stock shifter base, bead blasted and powder coated clear, Wevo shifter, 917 knob
![]() ![]() rear wing arms cleaned ![]()
