Power antenna question 82 SC
Cleaning some old wires from previous owner install.
Also installing my repaired power antenna.
Info says power lead goes to connector #30 on light switch ..agreed
Presently there is 1/2 of a fused connector on 30 .
Looks very Factory , so is this for the antenna ?
Is this typical to be fused for 82 ?
Frank
Gold71
Old 08-03-2019, 12:43 PM
Bill Douglas's Avatar
I was some time ago. But I think my power antenna just comes off the radio/sterio. No other wires used.
Old 08-03-2019, 08:45 PM
stevie 77 930's Avatar
3 wires from antenna....
Red: to light switch hot always
White: to the back of the radio switched when you turn radio on/off
Black: ground to chassis
Well illustrated in this F/S ad
FS: original Porsche Power antenna 78-86
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 08-04-2019, 06:49 AM
Stevie
Yes thanks,...saw the diagram.
My question was whether the power feed to #30 on light switch was fused ??
As I noted I have 1/2 of the in line fuse present.
Frank
Gold71
Old 08-04-2019, 05:53 PM
If you have the 1/2 of the in-line fuse, most certainly use it, not sure the power source for the light switch is fused.
1983 911SC
2018 GTS
2023 Audi A4
Old 08-04-2019, 09:36 PM
Thanks guys......did use the inline fuse .
Power for antenna .
All done
Gold71
Old 08-06-2019, 05:25 AM
