-   -   1973 Fuel Ruturn Line question - PHOTO (http://forums.pelicanparts.com/porsche-911-technical-forum/1036728-1973-fuel-ruturn-line-question-photo.html)
CCM911 08-06-2019 02:28 PM
Hello:
I am currently working on a 1973 911E fuel system. I am fine with the main fuel line from the tunnel in the body.
As for the return line. Is it the broken end that can be seen in the photo below? Are both lines on the same side of the tunnel?
Thanks so much.
http://forums.pelicanparts.com/uploa...1565130472.JPG
Blamecanada 08-06-2019 06:17 PM
They are on the same side of the tunnel on my 1977.
BoxsterGT 08-07-2019 03:54 AM
The 73 Model Year still had steel fuel lines through the Tunnel.
What you show is too large for fuel, so it's possibly the vent hose for the EGR. Correction, Charcoal cannister.
Thank you Art from 'Bama.
Len.Cummings at verizon.net
Artfrombama 08-07-2019 10:33 AM
I think what is pictured is a vapor line to the charcoal cannister.
hienz 08-07-2019 05:43 PM
My vapor line to the charcoal canister is brittle and has broken in to pieces. Since I converted my car to Weber carburetors and took out the charcoal canister. What should I do with that vapor line which supposed connecting to the charcoal canister? Any help would be appreciated. Thanks
BoxsterGT 08-07-2019 06:59 PM
Our host should have this in stock.
The cloth braided hose should be ok for the vapor lines but absolutely not for today's fuel.
Len
RWebb 08-07-2019 09:24 PM
hienz, best thing is to plug a new vapor line into the carb hookups - PMO has a kit for this
GH85Carrera 08-08-2019 09:10 AM
This. It will suck the smelly gas fumes back into the engine.
