My '78 runs 16" wheels, but my space-saver spare is 15". I don't know if 16" space-saver spares were made for SCs. I haven't been able to find anything about them, if they exist. So I've been trying to figure out if the later 16" space-saver spares will fit my car, re: lug pattern, offset, space-saver space in the trunk. Anyone know?
Thanks! ~r |
I have a 16" spare if you're interested. It's for a 964. I don't know if there was a 16" version for an SC.
965 spare wheel
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Vintage Owner
As long as the 15" fits over your brake calipers, it shouldn't make a difference if it's a 15 or 16" spare. If the inflated size is close, it'll get you home.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Thanks, guys.
Jack - are you saying that because of the difference in collapsible tire sizes mounted on either the 15" or 16" spares, when inflated the 15" unit (wheel and tire together) and the 16" unit end up with essentially the same circumference? If so, are you assuming, or do you know this? Just clarifying. puddy - maybe. Depends on what Jack says.
Rescuer of old cars
Jack is correct. The 15" spare when inflated is approximately 25" in diameter, which is also the diameter of either the stock 15" or 16" sizes offered on your SC. All SCs and 3.2 Carreras came with 15" spare, regardless of whether they had 15" or 16" regular tires.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Thanks, Arne2. I can sleep tonight now.
![]() I won't be needing your spare, puddy, but thanks anyway and good luck selling it. ~r |
But Randy, It would look soo good in your frunk! Hah no worries, its here when someone needs her!
Don't know if everyone knows this (I'd never thought about it or realized it until I read it in a thread on Pelican) - but you only fit the emergency spare on the front. So if you have a flat on the rear, you're supposed to fit the front wheel on the rear and the spare to the front. Apparently ![]() So the only reason to use a different spare is if the original won't go over the front calipers - e.g. you're running bigger brakes. But a 15" spare (or Fuchs) will go over 930 calipers (just) - so no need for a 16" spare until you go larger than that. I went to a 16" spare when I fitted 996 brakes. You can use spares from the later cars - don't remember exactly now, but I think 986 & 996 use the same part, there may be a difference for turbo - I forget.. ![]() In my case, this shaved about 25 years off the age of my spare tire rubber too
'77 S with '78 930 power and a few other things. Last edited by spuggy; 05-03-2015 at 06:07 AM.. |
Actually, it's for a 965 (964 turbo). Pretty sure that's different to accommodate the larger calipers (and a lot rarer). I looked for one of these...
'77 S with '78 930 power and a few other things. |
Vintage Owner
Actually, I don't know how many folks have actually inflated and used their spares. As they have been sitting there for so many years and rubber ages, it's probably best to treat it very gently and don't push it.
Has anyone actually replaced their collapsible spare tire? Mine has been sitting in the car since 1975.
Fleabit peanut monkey
928 362 030 02 is listed in the USA 78-83 PET 911 pdf It's available as a complete unit. Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI Porsche had to have thought of how long that tire may have to sit in that boot. Maybe..........maybe not? (regarding long time durability)
1981 911SC Targa |
Rescuer of old cars
I inflated mine as a test and to look for signs of age shortly after I bought my Carrera. Inflated fine, no cracks or weather-checking, and collapsed back to original with no drama. It does not appear to have ever been on the car so far, and I won't do so if I can avoid it. But I did want to test it in case of last resort.
ASE Master Tech - 35 yrs
interesting!
-mine is just in the trunk for show - b'ot it at Automotion swap about 35 yrs ago 165-15, load range D, Vredestein on a 6" rim - AAA is for flats ( or as a last resort for a dark rainy night, that can of "tire jack"
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Found this older (2015) thread - and am wondering if anyone ever inflates their spare to see if it's any good.
I'm almost afraid to - but also feel it wouldn't hurt to know if it's in good enough condition to be of use if and when the need arises. Some of these things are 40 years old now!
Old dog....new tricks..... |
