My fans and detractors alike will breathe a sigh of relief now, knowing that my exhausting exhaust quest is over at last. For tonight I bolted up a Dansk single-in/dual-out, and it's fabulous. I also have a Fabspeed premuffler in place of the cat, and stock heat exchangers. The premuffler is slightly cocked, resulting in the left pipe sitting a tad lower than the right. At this point I'm not going to fuss. It's not a show car. The OE stamped design of the Dansk fits so much better than the GHL and B&B "welding project"-style mufflers I tried.
I know the Dansk sound has been described a zillion times before, but here are my two cents, for what they're worth: it still sounds very "Porsche." It gives the car a bit more depth and rasp. I can still hear the fan, the induction note, the transmission, etc. A deeper exhaust note is evident at idle, but there's no resonance, and it never takes over in the cabin at all. I don't have to listen to the stereo any louder than I used to with the stock muffler. WOT and higher revs produce a nice howl, but it's not Cessna material.. just very sweet. A much more "German" choice than the burly, V8-like B&B single-in/dual-out I still have. (anyone want the thing?) And my seat-of-the-pants dyno gives it two thumbs up as well. The engine revs up and down more freely than with the stock muffler, and I definitely feel some more pull in the high end of the spectrum. There's no loss of low end grunt, like I got with the GHL headers & 2-in/2-out setup I had tried. Ahhh, finis!
~Hugh '84 Carrera |
Did you compare other mufflers? A lot of people seem to like the Monty.
SLR
Hi there Hugh
Yep just done the same on my 85 Carrera and I think the same as you just a very gutsy metalicy Porsche sound. I also added a K&N air filter and drilled the air box now even sounds better. |
I have a Monty single out with SSIs and it's wearing on me. The drone at idle and at constant speeds below about 3000 RPM is a bit annoying. When I'm on the gas, the exhaust note almost all but goes away in the cockpit and I hear mostly engine, but around town, it's getting old.
I had a gutted stock muffler mated to a cat pipe and stock heaters, and, although it didn't have the same 911 sound, it was much less intrusive. I'm probably being picky, because it's much less annoying than some B&Bs I've heard.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
Buy them, sell them
I can't complain with my Monty, although there is a marked difference in "the boom effect" (Copyright 2002 - My Girlfriend
) between driver's and passenger's seats. I let a buddy drive my 911, while I rode shotgun and was amazed at the difference in sound. He commented on it straight away, too.
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
Guest
Posts: n/a
George
Have you always had resonance with the SSI/Monty setup? I rode in a SSI-style Dansk with Dansk 2 in 1 out muffler and didn't hear any resonance at all? Could it be just the Monty muffler? I remember others reporting their Monty's to be free from resonance? |
I didn't really notice it during the first month or so. It has actually gotten worse over time. The muffler was only 6-8 months old when I bought it used, and I've had it for maybe 8 months and have only driven 600 miles or so in that time.
I've heard of mufflers changing over time, but for a 100% stainless Monty, I didn't expect this. I also feel engine vibrations more, like in the pedals. I thought this might be the club sport motor mounts I installed, but they don't look any different from stock ones. Any ideas about that? Maybe I should put it on a lift and check for integrity or any mounting issues that could be causing the vibrations. I haven't had the opportunity to do this since the install.
Hugh
Did you do the Stock 2 out conversion first before you went with the Dansk? If so, how did that turn out? thanks alf
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
SSI, 2 in 1 out Dansk sounds pretty good, no annoying drone like a "ricer"
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
Yeah, I was going to modify an OE muffler to have dual outlets, but decided it was: 1) too big a pain, and 2) never gonna be as nice as the Dansk.
~Hugh '84 Carrera |
