Front AC condenser location
I need the location of the front AC condenser in my 85 Carrera. I can’t seem to find a good photo. Thank you, nick.
Old 06-18-2020, 11:27 PM
If you lie on the ground at the front of the car and look up from underneath you'll see it hidden under a protective metal grill just behind the front bumper. If you imagine where the battery is just move across 30cm or so and you'll see it. It gets its airflow from a duct and fan located in the frunk and you will spot this if you have a look in there just left of the battery.
Davin
'87 Carrera 3.2
'66 VW Camper
'59 VW Beetle
Old 06-19-2020, 01:06 AM
Thank you very much!!!!!! Found it!!!!
Old 06-19-2020, 07:04 AM
Double check that fan that blows on it. The fan needs to work, and from the factory is is NOT fused, and has caused fires and roasted 911s. Be sure you have a fuse on it, if not add a fuse.
Old 06-19-2020, 07:08 AM
