New headers on 3.2, now 'puffing air' sound. Leak, headstud, ...?
I fitted new headers on my 3.2. Somehow it now seems to make a 'puffing air' sound when idling. Revving it a bit (let's say more than 1500rpm, also when keeping it stable) makes the sound disappear. My first thought is a leak somewhere. My second thought is a broken headstud, but since the car was running fine I don't think this is very likely. It would be very coincidental.
One of the 12 M8 exhaust studs isn't tightening very well. I don't want to torque is any further, because the threads are shredded. This may cause the puffing sound, but I don't see or feel any fumes escaping here.
Some questions:
- When a headstud is broken, is the sound supposed to disappear when revving?
- The threads in the cilinderhead have been damaged. I know about helicoils, but why not drill it with a 7.5mm drill bit and make a new M9 thread? I have one from I believe a VW T2 (M9 cilinderhead side, M8 exhaust side) like this: https://www.vwheritage.com/media/catalog/product/n/0/n0146841_1.jpg
Thanks!
Old 08-17-2019, 08:01 AM
cycling has-been
bkreigsr's Avatar
Originally Posted by sid86 View Post
....One of the 12 M8 exhaust studs isn't tightening very well....
Question asked and answered in the same post?
Bill K
Old 08-17-2019, 09:17 AM
Bill K
Obviously I’m thinking in this direction, but I don’t know if it is OK to fix with the stud I mentioned. I’ve never read anything about it being used on 911’s...
Old 08-17-2019, 09:41 AM
Just an update for whoever is using the search function in the future:
I removed the headers and cleaned all the ports. There was some old gasket stuff on there. Then I removed the loose M8 stud and drilled it with a 7.5mm drill. After 'tapping' (?) the new M9 thread in there, the VW stud was placed. It works fine and can be torqued appropriately. Lastly I removed both lower valvecovers to check for broken headstuds. All were in place and with a tip of the finger I checked them. After putting everything back together the sound is gone.
Old 08-19-2019, 03:57 AM
