which oil temp sender needed?
can someone confirm for me what the correct oil temp sender is for gauge 911 641 103 03
Thank you |
91160611200 - Goes to 300 F. Or in your case 150C. Check the inside of the gauge and you should see the top mark saying 150C. The sender should say the same.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
