Amateur
pmax's Avatar
I'm all for louder exhaust noises when there's the power to back up the pop, bang and gurgle.
I bet a Toyota Camry has more hp than most cars owned here.
I don't need that.
Old 10-08-2019, 03:03 PM
Originally Posted by Sebscst View Post
If you want really aggressive I have GT Racing muffeld megaphones. Lots of gurgles and pops. I would post a video if I knew how.
I for one would love to here this set up as i,m planning to go with GT,s cookie cutter pipes as well.
please post a video
Old 10-08-2019, 03:30 PM
82 911 SC - Ancora Imparo
Yes, please post a video!
Ethan
P-car: 1982 911 SC - Wine Red Metallic Coupe PB&J
Murica: 2017 Corvette Z06 - Watkins Glen Gray Metallic
Old 10-08-2019, 07:42 PM
Yes...more please. Getting popcorn.
Current:
1984 911 Targa Whale Tail
2014 Boxster S (wife)
Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4
Old 10-11-2019, 07:52 PM
How do you post a video?
78 911 st backdate
87 944
Old 10-12-2019, 03:38 PM
Text me.828-230-0788
Joe Bob's Avatar
Mufflers are for pansies....both of the sides on my 3.6 feed into a sports cat...
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 10-12-2019, 03:52 PM
Bland
RWebb's Avatar
those noises tend to suggest lack of pow-pow
what you want is a nice burble
keeps your lambda in line
Old 10-12-2019, 04:27 PM
My 3.2 sounds like a VW. And Always will.
Old 10-13-2019, 11:52 AM
A 3.2 will never burble . A V8 will.
Old 10-13-2019, 11:53 AM
Amateur
pmax's Avatar
Yeah, sounds like it's only for the noise but this appears possible with the Motronic.
“Pops and bangs, or burbles as the OEM call it (yes, it’s that common on production cars that even the manufacturers have a name for it!), is simply a calibration feature within the ECU where we set up a specifically targeted, very lean misfire once you lift off the throttle.”
Normally on an engine when you close the throttle, your fuel injectors don’t fire at all, removing all energy from your engine, allowing it to slow down: this is smooth, quiet, and safe, acting and sounding like all the sensible ‘normal’ cars we’re used to. No pops, no flames, no nothing.
Back to Stu’s words of wisdom… “If we want to create a burbling sound while the engine slows down, we need fuel. But, burning fuel will create some piston load too, slowing the rate the engine will decelerate on the overrun – so we need to move the energy away somehow to prevent that,” he explains. “To do this we need to do two things: retard the ignition timing to reducing the torque which allows the car to decelerate normally, and run a very lean air/fuel ratio so too much heat isn’t created,which could affect reliability.”
The heavily retarded ignition also means much of the combustion happens with the exhaust valves open (in fact within the exhaust system), and much of the fuel is ignited by the hot exhaust and/or catalytic converter, hence the burbles, pops and crackles you hear from your tailpipe.
DOES A POP AND BANG MAP HAVE ANY PERFORMANCE ADVANTAGE?
No. This is done purely for the noises.
As it works in a similar manor to rally anti-lag systems, really extreme set-ups could, in theory, work like a mild anti-lag system on a turbocharged engine, helping keep your turbo up to speed. But in reality, the pops, bangs and burbles usually happen only for a few seconds after you let-off the gas, and it’s done purely for the sound.
https://www.fastcar.co.uk/tuning-tech-guides/pop-and-bang-maps/
I don't need that.
Old 10-13-2019, 12:15 PM
I had a misfire!!!! Car is fixed. Never want it again.
Old 10-13-2019, 01:28 PM
