915 push clutch with beetle engine
Hi all,
Which pressure plate would work when hooking up a 915 with a pull clutch with a VW type-1 or type-4 engine with a 215 or 228mm clutch disk. Sent from my iPhone using Tapatalk Pro Last edited by Andy Somogyi; 08-17-2019 at 09:26 AM.. |
cycling has-been
Not much info in your inquiry.
What is the vehicle? The type 4 engine uses a 215 mm clutch/pp package. Clutch packs are usually matched to the bolt pattern on the flywheel. Make sure that the clutch splines match the splines on the output shaft of the 915. FWIW, a 912E uses a 923 trans mated to a type 4 lump. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 08-17-2019 at 09:12 AM.. |
You need to use a 912E trans with a push clutch as stated. No pull type clutches for a bug/bus engine. Or use a '69 and earlier 901 trans. Most bug conversions use the 901.
RETIRED
Or get a conversion flywheel from Kennedy Engineering.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Basically I’m trying to fit a 915 trans to a 914 type-4 engine in a rear engine car. The 912e uses a push clutch, as far as I can tell, the only difference is the 912e has a different clutch fork, but otherwise the same trans other than gear ratio. The clutch throughout bearing on the 912e is crazy insane expensive, so I’d like to use a 911 style pull clutch. 912e parts are next to impossible to find, way easier to source 911 parts. So I’m trying to figure out what the flywheel depth is on the 911 engines and see if a 911 pressure plate would work with a type-4 flywheel. Sent from my iPhone using Tapatalk Pro |
No, the clutch splines on the input shaft are different, and the cable is routed differently.
Jon B. Vista, CA |
I've got a Type 911/00 4 speed gearbox in my 69 912 using a 2.0 liter Type 4 engine if that helps you any. Here are some comments that may be of interest to you.
What is my type 911/0X transmission where “X” is “0” with superimposed “1”? |
