Left Mirror gasket install
89 911
I need advice on how to change the power mirror gasket .
Don't want to break the mirror . Does the mirror just pop off ?
Thanks in advance
Vince
Sure I can drive a stick !
Old 08-18-2019, 07:56 AM
Easy way, cut it at the bottom and slip it around the wires, if you can put up with the little gap.
206 637 4071
Old 08-18-2019, 11:51 AM
Ctopher's Avatar
Don’t cut the gasket, it’s not that much work to take the mirror off. Here is the procedure from my 87 manual.
Take a quick picture of the harness before you disassemble to be sure you go back in the right order.
I did this process before getting car PPF installed. Installed new gaskets easily and reassemble with no real fuss.
CTopher
Old 08-18-2019, 12:45 PM
Thanks! I assume the flag mirrors are all the same throughout the years? I have a 77 and was thinking I need to remove the door panel to back date the mirror.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 08-18-2019, 12:58 PM
proporsche's Avatar
CTopher
exactly like this...to remove the male connectors you can use old type pen (metal not plastic) it has the same diameter to push the connectors out of the socket..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 08-18-2019, 01:18 PM
Ctopher's Avatar
Ivan
Yep yep....I ended up purchasing this tool kit. Comes in handy for all types of electrical connectors and has the correct one for the Porsche pins.
https://www.amazon.com/gp/product/B007WQQHA2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
CTopher
Old 08-18-2019, 01:32 PM
left mirror gasket install
Thanks Everyone .
Done , Easy Peasy !!
Old 08-18-2019, 07:49 PM
