-   -   twist and twist and twist (http://forums.pelicanparts.com/porsche-911-technical-forum/1037752-twist-twist-twist.html)
IS300 08-18-2019 07:43 PM
went out to drive the 911 today ... put the key in the drivers door lock
and twist and twist and twist...
lock did not open
what happened ???
can the cylinder all of a sudden go bad???
help.............................................. ...........................please
darrin 08-18-2019 07:55 PM
see this thread -- i had same problem with my non-central-locking 911 and it was a relatively easy fix once I took the inner door card off to locate locking mechanism -- literally a single loose screw -- http://forums.pelicanparts.com/porsche-911-technical-forum/597984-door-wont-lock-key.html
IS300 08-18-2019 08:05 PM
sorry its a 1982 SC
IS300 08-18-2019 08:06 PM
thanks ... I'll check the screw
john walker's workshop 08-19-2019 03:58 AM
Gotta take the handle out to get at the screw.
IS300 08-19-2019 05:21 PM
Took the handle off ....
tightened the screw and it WORKS!!!
thanks for helping!!!!!
