Where can i buy carb cleaner that will melt your hand????!!?!
I'm tired of wasting my money on this environmentally friendly ****. Anyone know where I can get the real nasty stuff that will take you hand right off? I am willing to drive 2,000 miles to get it.
Old 08-19-2019, 07:34 PM
I picked up two gallons of lacquer thinner in New Mexico last year. Turns out to be the same "water" they sell in California. It just turned greasy car parts into sticky, oily parts.
Just doing my part to cure the sunburned penguins in Antarctica.
Give me old McKay's Parts Dip in a one gallon can. That'll take the chrome off your bumper hitch. Your hands smelled like it for days.
Old 08-19-2019, 07:51 PM
YES! there has to be a shop out there with access to this stuff! No way you can do business without it. Any shops in SoCal with access to this stuff? Anyone know aircraft equivalent chemical that works?
Old 08-19-2019, 07:56 PM
I'm thinking Mexico. But I'm sure it's illegal 8 different ways.
Old 08-19-2019, 08:00 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Dichloromethane , DCM, methelyne chloride, all the same stuff, solvent. Make your liver into a lava rock. Find some biodiesel, will dissolve grease, paint, cheap, and easy to store, metal, not plastic.
Methylene Chloride was the stuff in the old carb dip. Never want to smell that again.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-19-2019, 08:01 PM
Senior Member
Superman's Avatar
This. biodiesel might be the answer. Sometimes, often, vinegar is the answer. It certainly is an excellent remover of oxidization (rust). Where I have to bring out the big guns to degrease and totally strip a part....brake cleaner. But I use rubber gloves which I recommend strongly.
Old 08-19-2019, 08:05 PM
https://www.ncbi.nlm.nih.gov/pubmed/1541163
Old 08-19-2019, 08:06 PM
ROW '78 911 Targa
timmy2's Avatar
Acetone and transmission fluid works wonders if you keep the lid closed.
Then the crappy stuff to remove any residue.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-19-2019, 08:09 PM
If DCM is heated to decomposition, numerous toxic components are released, Phosgene is one of the nastiest. Gotta be careful with chlorinated solvents.
Old 08-19-2019, 08:12 PM
proporsche's Avatar
we have the same problem in Europe..i have found this one it even takes the paint off if you are not careful;-)
Ivan
1985 911 with original 493 284 miles..s..793 865 km
Old 08-19-2019, 10:33 PM
B12 chemtool.
206 637 4071
Old 08-20-2019, 01:41 AM
I gave up and built a vapor honing cabinet cleans everything to better than new without the cancer.
Old 08-20-2019, 03:48 AM
It all depends on what you are cleaning. Super Clean will remove grease easily and quickly, but it can eat aluminum if you soak a part in the stuff.
For many tasks I use the B12 Chemtool just as John Walker says. I buy that stuff regularly. It is handy to use on because cleanup is easy, it just evaporates, and leaves the crud on the large steel pan and the plastic pan I catch most of it in. Wipe out with a paper towel, done.
43 Year member of the Porsche Club of America
Old 08-20-2019, 05:34 AM
Back in the 70's we used a product called Magnus in a large tank. I believe they still sell it.
It will take your skin off.
Old 08-20-2019, 06:00 AM
Text me.828-230-0788
Joe Bob's Avatar
Don’t they still sell purple stuff? One to one water mix ratio
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 08-20-2019, 06:11 AM
He did say carb cleaner.
206 637 4071
Old 08-20-2019, 09:07 AM
proporsche's Avatar
there no products from Wurth in the USA any longer?? i have always used them or from ZEP also.
Ivan
Old 08-20-2019, 09:22 AM
proporsche's Avatar
actually when i moved to Europe i brought with me 2 boxes of this carb cleaner it is also perfect...
Old 08-20-2019, 09:48 AM
SCadaddle's Avatar
When rebuilding my 911 engine several years ago at a friends shop, he had a drum of what I called "The Toxic Soup". This stuff was old bio diesel, regular diesel, old gasoline and any kind of left over solvents he may have had on hand. Had to use very heavy rubber gloves handling that stuff while using a parts cleaner brush to clean things.
I still get a whiff of it when I pull the heat levers in the 911 as I used it to clean my heat exchangers.
But when it came down to the "final cleaning" of what the soup and the brush wouldn't get.......regular old Starting Fluid in an aerosol can. You'd better wear good heavy gloves with that stuff as well.
Old 08-20-2019, 11:58 AM
Berryman Carb Cleaner. The original formula has been superceded by environmental regs, but according to reviewers, the latest version still seems to do the job. Here's a link to Bezo's website:
https://www.amazon.com/dp/B00DSMEL2A/?creativeASIN=B00DSMEL2A&linkCode=w61&imprToken=nCGWhbmOpvnOd77yYqOMaw&slotNum=1&tag=car-search-20
The original stuff would remove carbon from the tops of pistons overnight.
Sherwood
Old 08-20-2019, 04:49 PM
