JED
ARCSinAK's Avatar
CIS fuel line sources??LEN MIA?
I’ve had a failure of my hard line cracked just past the crimped fitting at the front near the fuel pump. After reviewing the forum all advice said to use Len, called his shop they said he retired, tried a old email no luck.
Anyone have a source. Had to cut polymiad line and just barely got a heated section of 3/8” ID over hard line to make it home from firehouse, non fuel injection SAE 30RZ.
Not the recommend solution I know but what was available at ACE.
Guess I’m in for the fun and exciting task of replacing tunnel lines��.
Interesting my 74 has the poly lines and the pump is at the front.
Is there a more permanent temporary fitting that can be used on the short ploy line that I have left.
Old 08-20-2019, 11:20 AM
Try this email. He is still active, at another location.
len.cummings at verizon.net
1983SC RoW
Old 08-20-2019, 12:38 PM
JED
ARCSinAK's Avatar
I will try that thank you. Anyone have a opinion on a fix for my conditions until I get new lines?
Old 08-20-2019, 12:53 PM
Fuel lines..........
Use fuel injection rated fuel hoses and Oetiker type clamps. Make sure the rubber hoses are rated for FI application not just fuel hose application. Plus they are easy to fabricate compared to the polyamide plastic tubes.
Tony
Old 08-20-2019, 03:40 PM
BoxsterGT's Avatar
Porsche Crest
I am happy to help.
Please email me at: Len.Cummings at verizon.net
Len
Old 08-21-2019, 06:07 PM
BoxsterGT's Avatar
Porsche Crest
ARCSinAK -
I believe I am caught up on all my emails, but do not recognize or find your message.
It always helps to identify your request when your Pelican name is included.
How can I help you?
(Please use @ in place of the "at" above in my email address.)
Thank you.
Len
Old 08-26-2019, 12:30 PM
lespaul's Avatar
I have a '78 SC with the OEM plastic fuel lines. I have an opportunity to purchase a complete CIS system with the metal lines for a very reasonable price. I see that Paul Mason and Len Cummings both offer fuel line replacement systems. And Tony suggests that replacing the fuel lines can be done by fabrication.
Can anyone comment on which of the options available is a) safest and b) easiest?
I am also going to face this issue when I restore my '73.5 CIS T.
Thanks for your input.
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
European Patent No. 3256703 and U.S. Patents Pending
Go to SNAPGAP.US or PM me.
Old 09-06-2019, 06:37 AM
BoxsterGT's Avatar
Porsche Crest
I can advise you to go with the all metal lines on your motor. Not that the Polyamide lines are not good, as they are practically bulletproof.
But the steel lines are bulletproof, so buy them if you can.
I am happy to help with chassis lines that are Polyamide. Far easier to install than any other option, and they will last the lifetime of the vehicle.
Len
Old 09-07-2019, 06:34 AM
lespaul's Avatar
Thanks for the advice Len. Sent you an email.
Brad
Old 09-07-2019, 07:05 AM
