It started off as a simple valve adjustment...
...and quickly evolved into this :D
http://forums.pelicanparts.com/uploa...1566523905.jpg http://forums.pelicanparts.com/uploa...1566523905.JPG http://forums.pelicanparts.com/uploa...1566523905.jpg http://forums.pelicanparts.com/uploa...1566523905.JPG http://forums.pelicanparts.com/uploa...1566523905.jpg What an awesome and beautiful lump |
Because??
Decided to finally fix the leaks that made such a mess of the engine, and which also made the valve adjustment job pretty unpleasant - everything was coated in a dirty oil residue.
At one of my first jobs, the old guy who owned the place could whip out a 911 engine in less than a half an hour. I swear he'd pull it out for anything more than an oil change (slightly exaggerating, but not by much). After awhile, I felt the same way, too. Valve adjustment AND an oil leak from something on top? It's coming out!
It started as a valve adjust......
And then a head stud fell out:eek: Fixed it with a 3.6L:D |
Gotta love that jack stand , tripod (?) and the rotted pallet.
So... did you get your valves adjusted...? ;)
Rotted pallet? nah that is just nicely weathered....
but do wonder why you used it? I am also moving toward the 'pull the engine' for anything more involved than oil change. same with my 944s for anything involving getting to the bell housing. good luck. |
Same here. In 2003, pulled the lower valve covers for a routine valve adjustment and it started raining headstuds. :eek: Engine drop #1.
Seven engine drops later, I have the tools and checklists to take the stress out of the process. Still takes almost two hours to get it out and on the stand, but can do it alone and know I'm not damaging anything. |
Think you could share the list of tools and checklists? I’m always on the lookout for those who have created such guides - I’ve not pulled an engine yet, but my oil consumption figures indicate I’ll have to do so...
You have been blessed. That engine chose you as its rebuilder.
Praise be to the Porsche Flat 6. |
What lift do you have? I'm considering getting a 4 post and the engine obviously fits between the rails of your.
Well ... that's one way of doing a valve adjustment ... lol
After the last one i did , i decided to install a 95 3.6, no more valve adjustments ... wooooohooo ! |
The lift lowers enough for the jack ?
Any broken studs?
Someone has to ask.... |
Rotted pallet was outside for over 9 years, it was what my 4-post lift was delivered on so it's appropriate ;) |
Didn't have the stomach to hang the car's ass over the back of the lift, which seems to be another popular alternative when doing a drop on a 4-post. |
Of course, now I can't move the engine anywhere but plenty of space to work underneath the car since it's not going anywhere either. |
Did you lift the car off the engine ?
I made a sling and picked up the rear of the car with an engine hoist using the two holes for the engine mounts in which i inserted two large eyebolts. Had to make two stands out of wood blocks to get get the front wheels off the ground about 12 inches and i was able to slide the engine out from under the car without removing the rear bumper ... Ahhhhhh ...memories !!! |
Yup, car lifted and engine stayed put.
