-   -   sump plate torque and sealant questions (http://forums.pelicanparts.com/porsche-911-technical-forum/1038231-sump-plate-torque-sealant-questions.html)
LCOX 08-24-2019 09:30 AM
Anyone know the proper tightening torque for the 6mm nuts that mount the oil sump plate to the bottom of the engine?
- Also do you use any sealant on the gasket or plate or just install it dry? Thanx L
Superman 08-24-2019 09:58 AM
No sealant. Proper torque is less than one might think. Virtually just a little tighter than finger tight. If it leaks, it's because someone overtightened it and deformed the flatness of the plate.
Trackrash 08-24-2019 10:37 AM
The spec is 7 lb/ft. I use Curl-t sparingly and have no leaks.
Just use a 1/4" socket wrench and cinch them up gently.
proporsche 08-24-2019 01:04 PM
one more thing..make sure you use 2 gaskets...and the best is graphite type..use nylon nuts with alu washers not any other nuts with springs washers....
Ivan
