Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Stainless Steel Brake piston problem
I was trying to rebuild my S calipers today and I ran a small problem. The retracters that are in the original didn't come with the SS pistons. I thought about trying to move them over but there doesn't seem to be a ring for the clip to snap into.
Do I install them without the retracters?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-03-2003, 07:20 PM
Tim,
If you got the piston from the place I recommended, there is a groove for the snap ring, at least in mine there were.
You might need to stretch out the ring a little to hold the ring in place, plus the fit is a little tighter than the old ones. Perhaps you got an unfinished set.
Neil
'73 911S targa
Old 04-03-2003, 07:30 PM
Tim Walsh's Avatar
these are the one's from performance products. They were labeled weltimiester.
Tim
1973 911T
2005 VW GTI
Old 04-03-2003, 07:39 PM
