DC/electric Air conditioning
Has anyone tried this product,
http://www.cruisencomfortusa.com/hot-rod-series-1 I’m looking for electric air con alternatives to the UK product which has been widely discussed on pelican. |
Vintage Owner
In looking at the size of their components, I’d imagine the units from the UK would be a much better solution as they are designed to fit onto a 911 without much modification of the dash, etc.. I imagine we may see other alternatives emerge, but the UK units looks to be pretty nice and inconspicuous.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
I think the pricing on the UK unit is considerably above the unit above and all other ac units that I’ve seen. Hard to justify that price on ac and no future buyer will either.
Well, go ahead and buy that unit, cut up your car in order to make it fit and report back.
Ass-engine Nazi slot car -- PJ O'Rourke |
The systems you are looking at are much larger and do not look like they would be a good fit in the confined area of a 911. But if you are driven by price then maybe nothing else matters but the bottom line and you will be happy making sacrifices in other areas, mainly aesthetics in this case.
Follow me on instagram, @flyin.hawaiin www.davekealoha.com |
65lbs and looks to be bulky (square) - not sure how well it would fit?
If you give your word: keep it. |
"The systems you are looking at are much larger and do not look like they would be a good fit in the confined area of a 911. But if you are driven by price then maybe nothing else matters but the bottom line and you will be happy making sacrifices in other areas, mainly aesthetics in this case.[/QUOTE]
Dave your clients are 1% ers. Don't get me wrong love your stuff. I think we forget some times that MOST of our cars are high mileage, had inattentive owners along the way, are already "cut up" to some extent and will never be concourse high value cars. Further most of us HAVE to be driven by price. That said ~ $3K is a huge chunk for AC for a fun car for me. What is the $ delta to the UK system? I figured it was expensive but I thought it was in that ball park.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Why go electric at all? That system is heavy and costs about the same as a good aftermarket traditional unit that will bolt right in.
I picked a generic year for example https://www.classicautoair.com/shop/1980-porsche-911-non-turbo-lhd-air-conditioning-system/ What would be the advantage of the VES system? $3,000.00 and you need to fabricate several items to make it work. So add another $500.00 +/-. .
Derrick |
That said ~ $3K is a huge chunk for AC for a fun car for me. What is the $ delta to the UK system? I figured it was expensive but I thought it was in that ball park.[/QUOTE] Ok, now I feel like a complete snob, I'll jump down off my high, high horse now.
The 9 Store
There’s a lot to be said for buying a system that’s designed from the ground up to fit our cars.
All used parts sold as is. |
A number of reasons:
1) Weight. E.g. Our system is roughly half the weight of the original AC, plus it is at the front. (The system posted by the OP is heavy though) 2) Power. Our system uses less than 1 HP. It doesn't even affect the idle speed of the engine when switched on. 3) Efficiency. Electric compressors make much better use of the power available. They are capable of using less power when demand is less (once cabin is cool). Cars running electric compressors can see fuel savings of 15%. 4) Convenience. Electrical hookup is simpler and more flexible when it comes to packaging the compressor. It does not have to be driven from an engine belt so can live anywhere in the vehicle. 5) Appearance. 911‘s have particularly beautiful engines. The belt driven compressor is an eyesore. Right now, electric compressors are used in all electric vehicles and most hybrids. Nearly all truck cab and RV coolers use electric compressors too. In ten years time, ALL vehicles will use electric AC compressors.
www.classicretrofit.com Last edited by Jonny H; 02-22-2018 at 02:45 PM.. |
Eng-o-neer
40-50A current draw is nothing to sneeze at when your alternator puts out 90A and you want to fire an engine, blow air around, and drive at night. The fuel pump alone is on a line fused to 25A...Unlike nearly every motor in existence, it's extremely costly to get a higher-output alternator in one of these things.
I believe this is the primary reason none of the "vintage air" packages work on our cars. You just wind up spending more getting around certain character-enhancing limitations... It just really seems to be $3-5k any way you slice it. |
![]() Regarding the alternator, watch this space!
www.classicretrofit.com |
(man/dude)
Nice looking install - I see it's an early car without dash vents. So the cold air is simply routed out the defrost vents and foot wells?
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
(man/dude)
Outside Condenser Size : L 4 1/2" x W 20" x H 14" Compressor Size: L 10" x W 10" x H 10" Inside Evaporator Size: L 7.5" x W 18" x H 8.5" Not sure how much you'd save over the UK system but I think in terms of value the one designed to fit, integrate with, and simplify the 911 would be a much better proposition. If cost is your primary concern your best bet would be to fix and or re-install the factory AC - lots of people rip them out so used parts should be affordable. And it almost sorta works
Having gone through a complete factory system upgrade in my '89 25th Anniversary Edition (Rock and the boys at RetroAir took care of me good), and having chosen the Classic Retrofit kit for my Rat Rod I have a few thoughts on this.
Jonny's System solves all of the issues that Rock's is hamstrung by because Rock is doing it that same way the factory did, though with MUCH better parts.
I really do think that if Porsche were to design an A/C system for these cars now, they would do what Jonny & Co have done and just add cabin air filter and a dial to control the cabin temp. It's all modern equipment, in a very simple and well-engineered install. The technology just did not exist back in the day when these cars were built. And again, I go back to my total sunk costs on the RetroClassic System. That system is the best of the factory style systems, is $2,600 plus install. Running the lines all over to replace the old ones was more work than I wanted to do in my driveway. So I paid a good shop $1,500 to get it all in and set up. That's $4,100 all in and yes it works very good. It can blow sub 40 degree air 100 degree Florida heat and humidity. That's no easy task, and I would recommend it to anyone looking for a factory style system replacement. It keeps the car cool for sure. In fact I chose it for Anni before Jonny's system was available, but I would do it again today in that car. That is because that car was a factory air car from '89, it is a rare car (1 of 240 built) and when she is at shows (she has 107k miles and is very much a driver) she needs to look like a factory air car. In the Rat Rod for the same money effectively though I will have a far better blower, a far more simple and modern solution that gives better performance, I can install it myself, it will look clean and like a non-A/C car, an will blow Anni's A/C performance away. In all my research and trying to save as much money as I could I learned a few things with 911 A/C System selection.
That's just one buyers thoughts, jotted down over a cup of coffee. Just my 2 cents, and you did not pay for it.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Thx Duc. Very thoughtful/helpful post indeed. Would appreciate thoughts from any others that have tried other electric drive A/C options (other than the UK one).
Mighty Meatlocker Turbo
![]() Quote:
I have nowhere near the costs in components and supplies, including quality a/c tools, of any kit on the market, and you can hang meat in my Turbo on even the hottest of TexAss days. BUTT I am not counting my learning, experimentation and fab time into that equation, otherwise my system would likely cost more than the car (good thing I enjoy that kind of work - even with the frustrations that come with it).
Still confused by the 'expensive' comments.
Let's compare apples with apples here for a minute: The VES system above is $2700 less hoses. You get a generic condensor and fan ($100) and a generic evaporator like this ($82): To build the same system with our parts: Our compressor/ecu is £1750 which is $2435 at today's rate. Add the same parts ($182) and that makes $2617 That makes us better value. Plus... When you buy the compressor from us you get an custom ECU with real-time current monitoring, a full wiring loom, a control button and the brackets to fit perfectly in a 911 smuggler's box or ahead of the fuel tank. [Yes, our full kit is more because of the substantial R$D costs required to develop and tool up for a blower that fits like a glove into a 911 shell.]
