IS300's Avatar
Can you tell me what this is???
It was inside my 1982 SC
Passenger side door
Old 08-31-2019, 10:07 AM
Shaun @ Tru6's Avatar
Your pics aren't loading because they are .png's. Save as .jpg and post as a reply or copy from the reply and post in editing screen of first post.
Tru6 Restoration & Design
Old 08-31-2019, 10:24 AM
carreradpt's Avatar
A part of the window.
https://forums.pelicanparts.com/porsche-911-technical-forum/1033916-window-regulator-pivot-one.html
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 9's, Steve W chip
Kuehl AC and fresh top end
Old 08-31-2019, 11:16 AM
IS300's Avatar
live with slow windows... is what get from the other posts... and ways to fix.
thanks
Old 08-31-2019, 11:52 AM
Text me.828-230-0788
Joe Bob's Avatar
Part of the window regulator.
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 08-31-2019, 11:55 AM
The pin that holds the spring in the window regulator. Cheap part to replace and not a difficult fix but it does take some time to remove the door panel and window regulator.
Brian Miller - Scottsdale, AZ
1962 Devin C :: 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 08-31-2019, 12:37 PM
rnln's Avatar
window regulator. This part should be in the middle of the coil/spring, if I remember right.
Fat butt 911, 1987
Old 09-05-2019, 11:56 AM
Its a spring perch that was pressed on to the regulator.It should be aluminum mine did the same thing. I saw some people used a bolt to fix.
Old 09-05-2019, 06:56 PM
There's always confusion over this part. There's two pieces one in the center of the spring and one that holds tension on the spring end. Yours is the spring end and is not an available replacement part. Plenty of threads on building your own. The piece in the center is called pivot return spring I believe and can be purchased.
Old 09-06-2019, 05:23 AM
Part on left center replacement, right your part na
Old 09-06-2019, 05:41 AM
Rennline offers an aftermarket replacement for the spring end piece. There are two different lengths available.
Frank Amoroso
1987 911 M491 / M470 Coupe
1988 911 M491 / M470 Cabrio
WTB / ISO: G50 911 M491 Coupe or Targa
Old 09-07-2019, 05:09 AM
