Wheel Stud Fitment
I need to install longer wheel studs to accommodate a second set of wheels that are thicker than the Fuchs by about 4mm.
Just enough that the nuts are a turn short of full engagement.
I found Porsche part numbers, both 49mm long, (90133167100) and (PCG33167100).
There is not agreement at sellers about whether or not they will fit.
I suspect it is just a matter of whether or not these parts were used originally on a 1984 Carrera 3.2, but do all hubs use the same stud head and knurl arrangement?
Bob D.
'84 Carrera - MAF, Wong chip, RSR flywheel, ER bushings and other bits, CTR fiberglass F/R bumpers, 7/9 Fuchs, 21/27 TB, 22/21 SB, bunch of other little stuff
'74 Fiat X1/9
2021 X5
Old 09-03-2019, 02:56 PM
Yes.
206 637 4071
Old 09-03-2019, 04:03 PM
cycling has-been
bkreigsr's Avatar
Handy-dandy reference material.
https://www.elephantracing.com/porsche/wheel-spacers/wheel-spacers-studs/
Bill K
Old 09-04-2019, 08:56 AM
Thanks for the info, John.
I've been to the Elephant and every other site I can find; reference to the 49mm studs I want to use is missing/in conflict.
Since the hubs are all the same, either one should work.
Bob D.
'74 Fiat X1/9
2021 X5
Old 09-04-2019, 02:36 PM
kent olsen's Avatar
I remember putting longer studs in my 72 many years ago to accommodate my new Australian Superlites. As I remember after pulling the disc the fronts went in easy, the rears where a pain but I finally got them in.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 09-05-2019, 10:06 AM
