'917' Gearknob
Does anyone know the diameter of the '917' wooden Gearknob?
They look like 50mm but this seems to be on the big side. Tahnks |
1968 2.0s
Afternoon Chris, hope you are well. Tr Motorsports has them at 48mm...
917 Style Although Jamies' were 43mm DDK - Die Deutschen Klassiker • View topic - 917-style Shift Knobs Here's one in situ if that helps, ![]() And there's a guy in Denmark making them, perhaps he can help. DDK - Die Deutschen Klassiker • View topic - Balsa wood or similar gearknob Regards, Mike.
1968 Super. 1959 Super. http://tinyurl.com/pbvfl5w Will this learning curve ever level out ? |
Mike,
Thank you, as with all these old parts there is a huge debate about original spec. I thought 50mm was a bit too big. |
Kind of Blue
Nice! I'm ordering one now.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Driver
Check with Slodave. He's been working on making replicas.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Kind of Blue
I have no experience or affiliation with this company but I did find this:
http://classicowheels.com/shiftknobs.htm
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor Last edited by MrBonus; 12-12-2012 at 11:11 AM.. |
PhD on Pending Projects
Oh man... I want one... for that future long hood project... might as well start buying and saving the parts.
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
I have got one from Marek Lappok from Denmark, really look cool and size is 4,3- 4,4 cm in dia meter.
You can PM him here on Pelican. ![]()
1988 911 3.2 Carrera @joost_hermes |
Were the originals not made of Balsa wood?...to save weight?
Don't believe they would stand up to every day driving. Bob
Bob Hutson |
1968 2.0s
...Let alone the ravages of the race track.
I agree, it's unlikely the gear knob was an exercise in trimming weight and I doubt a flimsy balsa knob would stand up the number of gear changes made in 24 hours at Le Mans. Far more likely, the originals were a mahogany/ash laminate, used to reduce heat transfer from what would become a very warm gear lever. Regards, Mike.
Gas Huffer
My cheap version made from these:
You can get 1.75" which would be closer to the 43 mm but I got the 2" which is the 50 mm and feels great!
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi 69 Porsche 911T - Project 04 Ford F-150 FX4 - Boris |
In my research, I have found that the shift knobs were not uniform. They were turned from various thickness of wood. I believe the wood was layered in a way that resembled plywood. The wood used was most likely beech. Beech/balsa... Both start with a "B", balsa happens to be light and probably helps add to the mystery.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 12-15-2012 at 03:06 AM.. |
I am fairly sure that they were 'yellow' Birch with the grain crossed in the laminations to stop it splitting.
I think this is one fitted to a 917. ![]() This one is 48mm dia. |
Birch alone, as you and others have described, would not create the patterns in your pic. But I'm 99% certain it would have been beech, not birch.
This is as close as I have come (one on the right), and this only mimics one knob. They are not the same. ![]() 48mm
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 12-15-2012 at 03:40 AM.. |
BTW, I don't believe the knobs were made from one type of wood. I tried laminating blocks of the same wood (birch), perpendicular to each other. I could not get the same results as the few pix that the Internet turns up.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
The harder grades (higher density) balsa look like the grain structure in this picture.
it would be interesting if someone tried that grade for the knob. Certainly a good choice for model airplane gliders where it will drag on the ground during landings. Can someone ask Norbert Singer? He probably knows! Quote:
leichtbauer
Original 917 shiftknoobs are balsa! The diameter of the hand-size are adjusted and are between 40 and 50 mm. The weight of a 44mm button is 18g. The reproduction is not easy.
My buttons are made of balsa. ![]() ![]()
AutoBahned
some wt. comparisons of shift knobs I use:
Momo Race Air Leather 8-hole shift knob 0.31 lb. 8 Ball shift knob 0.41 lb. Wood 917 repro shift knob w/collar 0.04 lb. |
Incomplete research , without some 0-60 times!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Heat transfer in old cars was certainly an issue, especially for longer races (GP races were # hr + back in the day). I heard Han J Stuck mention that for the Auto Union Type A-C that the drivers got heat blisters on their gas pedal feet and wore heavy gloves due to how hot they got.
1988 Carrera Coupe |
