Eric Mckenna's Avatar
What Would Cause This To Happen?
I will start the car up and it will, as it should run up to 2k. BUT!!!
it will stay there until i let it warm up and then turn the car off and let it sit for a bout 2 minutes and then re-start the car then it goes to idle where it should..
is it the WUR?
gone bad?
any idea's it's an 83 SC
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 03-27-2003, 06:35 AM
AirCooledExcellence's Avatar
Hi Eric,
Have you checked the electrical connections to your AAV (Aux Air Valve)? It's on the right hand side of the engine.
Cheers
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 03-27-2003, 06:40 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I don't know about the newer cars but that sounds like your cars still warm and has no need to idle at 2K after its warm. 2 minutes doesn't give alot of time for 3 gallons of oil to cool down.
just my speculation
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
IROC's Avatar
I'm not going to suggest this is your problem, but I had a similar occurence on my 2.7 where it would run fine for a bit, then the idle would go up to 2k and I could not get it to drop back down. Then it would magically clear up. I figured it was some CIS problem. Nope. My throttle linkage was catching on a vacuum line (or possibly the fuel return line) right down there where it attaches to the engine and not allowing it to drop back to idle.
Doh.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-27-2003, 06:43 AM
Somatic Negative Optimist
Gunter's Avatar
The engine needs more time to warm up then 2 minutes. AAV does not have an electrical connection; the AAR has. The voltage to the Aux. Air Reg. heats up the element inside and thereby closes the valve. I suspect that the heat from the engine has an effect on the AAR as well.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-27-2003, 06:56 AM
Sorry Eric, I meant AAR!
Cheers
1987 930 - SOLD
Old 03-27-2003, 07:35 AM
Send a message via ICQ to old_skul
I've seen Eric's car in action; it never comes off of the warmup period high idle. Even fully warmed up it idles waaay high until he shuts it down, waits a bit, and restarts it.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 03-27-2003, 07:39 AM
Thanks for the replies.. i'll check out some of the listed things and see what happensd.. if anyone else has some idea's on the matter please feel free to chime in.
Thanks!
Eric
Famous last words..
Old 03-27-2003, 09:27 AM
2k is too high. try putting in a new AAR, bet that will solve your problem
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 03-27-2003, 09:42 AM
fred cook's Avatar
Cool High Idle
Eric,
When I first got my '80 911SC, it did EXACTLY the same thing you are describing. I kept looking for the problem and finally discovered that the electrical connector on the AAR was not pushed completely into the socket. Just to make sure that the AAR was actually working, I took it off (not too hard, requires an allen wrench and patience), put it in a freezer for about 5 minutes to cause it to open fully and let it sit on the workbench to warm up and close. Once I was convinced that it was working correctly and was warm (closed), I tried to blow air thru the AAR to check the seal on the rotary valve. After passing all tests with flying colors, I reinstalled the AAR and made sure that the electrical connection was correctly installed. It has worked perfectly ever since. Total cost of repair, about 1 hour labor and 0$.
Good Luck!
Fred Cook
Old 03-27-2003, 04:56 PM
diy83sc's Avatar
Hey Eric,
Before you take the AAR off, try this. Take a small piece of wood or a soft hammer and gently tap the AAR the next time your idle hangs. If the idle drops, take Fred's advice. I had the same problem. Basically, the engine was not warming up as quick due to the constant flow of cool air at 2K rpm. Once the engine stops, the radiant heat is enough to get the AAR to close. Mine was gunked and is now okay after a light cleaning. I read this tip on another thread.
Tony
Old 03-27-2003, 06:59 PM
Thanks guys..
Thanks very much! VERY HELPFUL!
Eric McKenna
Famous last words..
Old 03-27-2003, 07:39 PM
