-   -   installing coilovers, reinforcement really needed? (http://forums.pelicanparts.com/porsche-911-technical-forum/1039344-installing-coilovers-reinforcement-really-needed.html)
Trakrat 09-06-2019 10:27 AM
I've noticed some people welding in some reinforced sheet metal on their rear shock towers.
Is this REALLY needed? I mean... has anyone ever seen a coilover being ripped from the rear shock towers or pushed through completely?
If you have, or have some pics that show the damage done, I'd be curious to see.
Harpo 09-06-2019 11:25 AM
The short answer is that photos have been posted with such failures. The question for me is do you need this an a street car.
john walker's workshop 09-06-2019 11:31 AM
Those shock towers were not designed to support the car.
Trakrat 09-06-2019 11:43 AM
I've looked, and googled, and still couldn't find anything... at least not on a G-body 911.
Trakrat 09-06-2019 11:50 AM
In that case, a pair of really stiff shocks could cause damage then?
3rd_gear_Ted 09-06-2019 11:59 AM
Reinforcement pieces to tub are welded in to spread the load properly
and some even add a complete length tube piece between both towers for more rigidity
David Inc. 09-06-2019 12:05 PM
They can and do. It's why they reinforced the shock towers for the 911 race versions.
r lane 09-06-2019 12:12 PM
The torsion bars support the suspension. Take the shocks out and the car still sits there. Coil overs, all of the load is at the upper shock mount.
stownsen914 09-06-2019 03:58 PM
Exactly. Huge difference in the force applied to the shock mounts.
Cdnone1 09-06-2019 04:29 PM
yes you really need to
Jack Stands 09-06-2019 04:38 PM
Unless you’re racing the car, the coil overs are probably overkill. The chassis wasn’t designed to carry the loads through coil overs without support.
Marc Bixen 09-06-2019 05:58 PM
Absolutely reinforce them Trakrat. I have seen the complete crossmember break loose at the welds. Car came in bouncy bouncy, like the shocks were gone, opened the rear and the whole cross member was moving up and down with the motion of the car. Gusset, Gusset, Gusset!
Walt Fricke 09-06-2019 09:41 PM
Better still, perhaps reconsider. Why do you want coilovers? There is no difference in suspension geometry between T bars and coilovers - both are just springs (assuming you aren't going to use taper ground titanium springs to get a progressive effect, as Porsche did on some race cars).
You can get a torsion bar which literally is as large as will fit the various holes, and is even larger than the inner spline diameter. I've got that on my track car. Pretty stiff for the street.
On a track car, the benefit of coilovers is the ease with which you can change them (not expensive, either, considering) to tune the car for this or that track or just overall. Do you plan to experiment on your car?
Of course if it is to be a track car, fine. Just reinforce. You can get away without it for a while. But just a while.
spuggy 09-07-2019 12:20 PM
almost everyone does. Both TRE and Elephant Racing sell reinforcement kits ready to weld in.
pictures of what happens when you don't - and a great explanation as to why you need to are both in this thread.
http://forums.pelicanparts.com/porsche-911-technical-forum/739625-rear-crossmember-tower-damage-pics-coliovers.html
juanbenae 09-07-2019 03:59 PM
this is a case if you had to ask, you really already knew...
tperazzo 09-07-2019 11:27 PM
Here's a pic of a tower failure.
http://forums.pelicanparts.com/uploa...1567923890.jpg
Not my car, so I don't know the failure conditions, etc.
daltvater 09-08-2019 01:50 AM
Point of reference, 1979, with 3.6, 935 setup, street compliant springs, JRZ's. Rear tower plates, some front reinforcement, increased space for springs, welded in half cage.
I put a crack in tub after a day at the track last year, didn't know it was there until I got home and swapped wheels.
Seems like an odd place for a crack but there it is.
Coilovers are a blast, car feels like a go-cart now, night and day, Doing a coilover conversion over here in New Zealand was a nightmare to get done due to the certification process....cad drawings required/suspension x-rays, all OEM parts, bump steer must remain unchanged over stock etc etc.
Crack at top:
http://forums.pelicanparts.com/uploa...1567929397.jpg
Welded up:
http://forums.pelicanparts.com/uploa...1567929647.jpg
Tower:
http://forums.pelicanparts.com/uploa...1567929921.jpg
Rear:
http://forums.pelicanparts.com/uploa...1567930180.jpg
