83 Targa
Just developed a front end slight rub...Bearing?
1983 SC......Just started getting a slight rubbed when turning slightly to the right at low speed. The wheel is not turned far enough for tire rubbing in wheel well. When the rub occurs, I can feel it thru the steering wheel. I’m guessing I might have a wheel bearing issue or maybe a brake caliper issue.
Thanks in advance for opinions and advice.
Last edited by NoYouRelax; 09-07-2019 at 10:38 AM.. Reason: Bad auto correct in header
Old 09-07-2019, 10:28 AM
BE911SC's Avatar
My recent sticking front ('84 911) caliper issue revealed itself as a buzzing up front at about 45 mph that would go away if I sawed the steering wheel back and forth a little. Then it would come back intermittently. Turned out that the RF caliper was dragging a little more than the LF was so the car pulled a little to the right. Had the brakes done and bearings repacked. Drives like new. FWIW.
'84 Carrera Cabriolet
Old 09-07-2019, 11:10 AM
83 Targa
Thanks BE911
Old 09-09-2019, 07:50 AM
