Shaun @ Tru6's Avatar
Originally Posted by Z06Racer View Post
Whats the problem with welding the original sunroof panel in place ?
Gap is too wide to make it worthwhile. Can be done but not optimal.
Tru6 Restoration & Design
Old 09-17-2019, 04:53 AM
Fixer's Avatar
They're too small gap is too wide to weid.. They're heavy but I'm guessing people do it.
I'm pretty sure the shape has a subtle difference too than a roof sans sunroof so they can tuck under. Very subtle though. I can check this and confirm.
The way to go imo is with one of the stamped panels using
*3M impact resistant structural adhesive (3M-07333) $65) which you can weld set in place also.
Then you heat it to 80F and it sets in 30 minutes. Stronger than welding.
Front and all rear glass out, door glass stays put.
Tape off glass openings.
Then with finest flap disc remove paint on roof and down the A and C pillars for blending paint. Feather paint edges toward glass opening.
Fill roof seam, sand, repeat, feather it out (PITA) and shoot epoxy primer once nice and smooth. Use light and guide coat to check. Allow days to cure (shrinkage) repeat.
Then fill primer and start sanding again until you can paint and blend color coat and clear halfway down the four pillars.
Drilling out the sunroof assembly and installing the panel are the easy parts imo.
Then you need to reinstall the headliner which isnt too bad.
Good luck!
Matt
Old 09-18-2019, 06:47 AM
plexiform's Avatar
I struggled with this during my build. I love the clean look of a deleted sunroof, but I couldn't get rid of it. I like the option to open it once in a while. So I ended up keeping mine.
2003 996turbo, 1975 911s, 2005 MV Agusta F4 AGO, 2002 Moto Guzzi V11 Scura, 2016 Norton 961, 1983 BMW R100RT
Gone but not forgotten: 2003 R1100s BCR, 77 R100s, 09 S63 AMG, 74 911, 88 R100RS, 78 930, 01 996 C4, 05 Cayenne, 09 Audi TT, 03 Moto Guzzi V11 LeMans, 07 WRX STI, 03 R1150GSA, 78 R100/7, 01 Audi S4, 98 Audi A4, 98 R1200c, 78 GL1000, 92 Accord coupe, 89 KE100
Old 09-18-2019, 07:11 AM
Seems like a ton of work to make your car look almost the same. I think with sunroof delete some value of the car is lost. Sunroof is nice on a warm spring day. But then again, I like my sugar scoops just fine.
Old 09-18-2019, 07:47 AM
Reiver
Reiver's Avatar
Well gents...that's why they make more than one style of shoes....
De Oppresso Liber
Old 09-18-2019, 08:55 AM
Fixer's Avatar
Agree,
I asked a very intelligent, well regarded and well known in the Porsche world..75 year old ex Holbert's and Brumos racing mechanic (with many SCCA trophies) what he thought of sunroof delete on 911s.
He said; "noone uses them anyway"
He owns several 911s and maintains historic factory Porsche racing cars for a living still.
Case closed in my book.
Old 09-18-2019, 03:33 PM
Reiver
Reiver's Avatar
Originally Posted by Fixer View Post
Agree,
I never used mine, and if you do, it is simply a small hole in the roof not an open air vehicle. The damned little felt strips were also a royal pita after a time.....and...the big and...I had to look at the damn thing that ruined the cars lines every time I got into it not to mention that is the dumbest place in the world for weight in a sports car...as high as one can get.
It also reminded me of the Euro's concept of what Americans want....superfluous weight gain.
Other than that they are fine
De Oppresso Liber
Old 09-18-2019, 04:56 PM
If you lose that top weight , a 1985 Porsche 911 could reach a top speed of 152 mph!!! And 0-60!in 6.1!! Holy smokes!!!
Old 09-18-2019, 07:58 PM
Reiver
Reiver's Avatar
Actually...a little here....a little there...and strangely enough it has lost about 400 lbs....
Holy smokes! Fully wet....500 dry....if that is meaningless to you then cruise on...
De Oppresso Liber
Old 09-18-2019, 09:37 PM
I’m
Just saying a 2014 Subaru wagon is still faster after all the effort. The roofline looks the same with the sunroof , A Targa does not.
Old 09-19-2019, 07:42 AM
Registered Minimalist
75 911s's Avatar
Objection! The roof-line does NOT look the same. Also, subaru wagons 2010-2016 show 0-60 to be around 10 seconds.
2016 Subaru Outback 2.5iⓘ
9.30 sec 17.20 sec
My base model 911 with no mods from 1975 is faster than that. :-)
Duane / IG: @duanewik
Check out my 75 and 77 911S build threads
Old 09-19-2019, 07:53 AM
don't overlook what the lack of a sunroof does to the lines inside the car. if you don't care, that's just fine. there is a considerable difference in a car with no sunroof aesthetically, performance be damned.
but i'm biased, and i'm removing the sunroof from my '74. that car should weigh around 2100 lbs when i'm done with it...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 09-19-2019, 10:11 AM
Reiver
Reiver's Avatar
Iím
Well Nick....why own a Porsche at all...get yourself a nice 2014 Subaru with a bigger sunroof....
De Oppresso Liber
Old 09-19-2019, 11:35 AM
I love my 85 911 and the way it smells and drives and corners. That is why I have my car. I’m just saying that removing AC parts, sunroof delete, back seats will just not make your car that much faster . And when it’s selling time, and we all sell in time, buyers just may want all that stuff. I sure would on a Porsche classic. Why do all this stuff when a mustang GT with 460 horsepower will
Pass us like we are standing still.
Old 09-19-2019, 04:50 PM
Now Now boys, didn't mean to strike a nerve......
I appreciate all the feedback. I'm collecting parts to do a 74 RS (IROCish) conversion on my recently acquired 86.
I expect the sunroof will go away and it looks like a formed panel with 3M adhesive will be the path forward. We'll limit the welding to the 930 flares recently purchased from another pelican member.
When completed I'm sure this will be the slowest car in my garage....but I expect it to be a pleasurable driving experience,
Old 09-19-2019, 05:39 PM
Reiver
Reiver's Avatar
Nick....it is like a fat guy losing weight....being nimble...digging out of corners....much better feel and responsiveness...
No one ever bought a 911 for 0-60...surprised one has to articulate that...as to selling...I could care less about that...but all the parts are stored...but, I really don't care...again, I didn't buy it for resale. I'll probably give it to a nephew anyway.
De Oppresso Liber
Old 09-20-2019, 12:37 PM
Next time you sunroof delete, use an Engish wheel.
This one turned out no filler required (okay a tiny amount) spot on 👍🏼
Hey looks great! I'm about to have my bodyshop do this to my '82 SC. I was going to get the Rennline panel (here) but I'm struggling with what is needed in the headliner area.
Do I just need new headliner for cars without sunroof (obviously), and then the headliner rods sold by Pelican (1 through 4?) and the accompanying rubber ends? Do I need new headliner clips? Anything else?
Thanks!
Old 10-15-2019, 01:19 PM
