Magnatec
I run dynamic coefficient of friction tests on transmission oils for work. Mobil 210 Type "F" is the most consistent oil our company has run across. It has the best linear torque curve over changing temperature. Very little torque fade. We highly recommend it for the products we sell (power transmissions for industries). But we have not check all the fluids out there.
I am going to test the Mobil synthetic trans oil next week vs the Mobil 210 "F" fluid. Would like to get my hands on some Swepco and check it. It would be fun to check the gamit of motor oils too. Jim |
Jim: please post you findings here.
I assume the trans fluid you're going to test is Manual trans fluid. |
Yeh please post the results try and get hold of some Castrol 'Magnatec' , they claim the molecules of oil magnetize themselves to metal and hence on start ups they claim your engine is better protected . I swear my engine is less smokey on start ups since I've started using it .
Sorry... no manual fluid.
We use Mobil 210 ATF Type "F" in most of our products. This is an old Ford spec for their early transmissions. Plus we run Mobil 424, which is a John Deere spec, slipping fluid for our constant slip applications. We have found Texaco ATF to have an "S" torque curve (instead of linear) vs temperature and the Texaco TDH (similar to Mobil 424) to chatter. But on the bright side for Texaco it did run approx 10 degrees cooler than Mobil ATF. Can post results when available. Jim |
Bones,
I have never heard of Magnatec here in the states. Is that an "across the pond" thing? Again not sure if I could squeeze the time out of work to test motor oils. Jim |
Maybe I could get our host to "donate" about 3 gallons of Swepco (enough for testing plus fill my 911 trans HeHeHe!!!), and I could compare it to another similar type of manual fluid and post those findings? What do you say Wayne?!?
Jim |
MAGNATEC
| All times are GMT -8. The time now is 08:19 AM. |
