bosch twin plug rotor?
Hi
Still on the search for a bosch twin plug rotor, new or used.
Tried German Auto in St Louis already
Old 03-25-2003, 02:00 PM
Super Moderator
cstreit's Avatar
BritWrench had one at one point, or at least knew of the whereabouts...
I think Steve Weiner might have one or two, but understandably is guarding them closely.
You know, I think THIS would be a much better oportunity for a co-op agreement ala Waynes idea with the GT flares from a few days ago... If you could produce these in a decent quantity, they'd most certainly sell...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-25-2003, 02:05 PM
Super Moderator
cstreit's Avatar
Okay so here's Chris' crazy idea... ...someone tell me why you couldn't get a really high output coil and use a Y harness off each plug on a single distributor to make a twin plug one...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 03-25-2003, 02:07 PM
Andial says no way jose- they are working on a company that says 1-2 years before they have them!
btw- Bosch lost the molds to the originals when they were in the moving process
Old 03-25-2003, 02:19 PM
not available at any price from them now
Old 03-25-2003, 02:43 PM
Cool Re: bosch twin plug rotor?
Originally posted by TRE Cup
Hi
would this be for the old 911 4 cam engine? where a dizzy cap can cost $300
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-25-2003, 02:46 PM
Steve / rennsport doesn't have any and yes the caps are in the $600-800 range now.
Old 03-25-2003, 02:52 PM
so that means that the rotor is for the old 4 cam engines.. like the engines that Gary at Parts Obsolete has?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-25-2003, 02:59 PM
There is probably a difference between the magnetti and the bosch rotors dimensionally. the caps should be interchangeable. We found a magnetti rotor and will report back if it can be converted for use on the bosch shaft
Old 03-25-2003, 03:03 PM
Cool
OK.. I was at the Parts Obsolete Camp Out last spring and hung with a shop owner for a few days from Glendale/Burbank.. a small 356/911shop.. if you can't find the name.. I'll start digging.. he has many of these crazy parts..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-25-2003, 03:08 PM
Chuck Miller's Avatar
Dave, I think your on the right track ...
I think I heard someone converting an old Maserati twin plug 6 distribuator and cap ... unfortunatly those are just is rare... but
Cheers,
Chuck
Old 03-25-2003, 03:18 PM
I left a message for the burbank shop- will post results
thanks!
RSR.guy's Avatar
Another shot in the dark here; you might check with the Alfa guys. I restored a '64 TZ (many years back) that I'm fairly certain runs a similar twin plug rotor (although the cap differs due to the number of cylinders). Many of the factory race cars ran twin plug heads; e.g., the GTA's, TZ-1, TZ-2's, etc.
You might give Phil Reilly and Co. a call. (415) 924-9022.
Cheers, Chris
Old 03-25-2003, 03:45 PM
Paul Thomas's Avatar
Is this what you're looking for?
Paul
My ignition is retarded.
Old 03-25-2003, 04:14 PM
Oops, better pic.
Old 03-25-2003, 04:16 PM
yes! i want... I want.... pant, pant,pant!
Old 03-25-2003, 04:28 PM
The good news is; you're welcome to it.
The bad news is, what i am pointing to in this pic is a hairline crack. If you want i can ship it out there and you can have a look. If you want it, fine, if not ship it back.
Paul
Old 03-25-2003, 04:40 PM
Super Moderator
cstreit's Avatar
Ummm.... You wouldn't happen to have TWO?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 03-25-2003, 04:41 PM
rs911t's Avatar
Chris, we two-point-eighters must be naturally nuts - I had the same idea. I can see why a super-dooper coil with a Y-connector wouldn't get the job done. The plugs are in effect shorting, so with two one would likely win and the other loose completely.
My thought was to use a standard dizzy as a trigger for somekind of dual coil setup. Mind you I'm no electrical engineer, but it sure seems a dizzy working with a low-power discharge could provide a signal to trigger a pair of ignition circuits.
Any automotive, EE types care to comment .... ?
Greg
Old 03-25-2003, 05:36 PM
