-   -   Is this a matching gear set? (http://forums.pelicanparts.com/porsche-911-technical-forum/1040113-matching-gear-set.html)
mikedsilva 09-14-2019 01:01 PM
I'm looking at a replacement set for 2nd gear for my 915.
Trying to ascertain if this is indeed a matching gearset. Both gears appear to have the same manufacturer stamp "73 H X *" but only 1 has the handscribed number "9972".
The smaller gear does not have this number scribed on that I can see.
I'm inexperienced with trannies so any advice is appreciated.
http://forums.pelicanparts.com/uploa...1568494764.JPG
jpnovak 09-14-2019 01:54 PM
9 73 should be year of manufacture. HX should be the gear ratio. The acid etched numbers are the individual S/N. They usually match the hand etched.
mikedsilva 09-14-2019 01:58 PM
Yes, so without the hand etched numbers on the smaller gear, there is no way to tell if they are indeed matching?
Matt Monson 09-14-2019 03:07 PM
That fixed gear looks kind of hammered. I would keep shopping. 1973 is the first year of a 14 year manufacturing run. I’d be looking for a gear made in the 80s.
And no, we can’t tell if they are matched but most likely they are.
mikedsilva 09-14-2019 04:26 PM
thanks Matt.
Mahler9th 09-15-2019 03:05 PM
It is a matching gear set.
It sounds like you have had some problems-- I think you should consider buying new gears. I can recommend the Guard Transmission gears. I have been using them for nearly 20 years.
KTL 09-16-2019 07:59 AM
HX is a very common 2nd gear ratio used in nearly all the 915 5-speed transmissions. You shouldn't have a hard time finding a decent used pair if that's the route you'd like to go.
I got a very nice HX from Mike Bruns. He may still have a few pairs on hand and i'm sure they're in good shape.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/981240-915-gears.html
kevingross 09-16-2019 01:06 PM
Gonna agree with Matt here. The chips at the end of the teeth in the first photo are certainly not a good sign. Little hard to be sure from the photo, but the tooth surface condition in the third photo (same part) looks dodgy -- could be the photo tho.
Mahler9th 09-16-2019 02:51 PM
As KTL has indicated, there are likely plenty of used HX gear sets around. If that one is not suitable for your application I am happy to suggest several resources that may have a better set.
For example, Partsheaven here in Norcal might have an Hx set or perhaps a few-- I hear they are liquidating everything. Good friends about 20 minutes from where I live.
Be ware that likely many dismantlers like them have not been able to buy as many 911 cars as a decade or so ago... so you may have to call around.
As we discussed via e-mail, I doubt your 915 situation is a worn out 2nd gear, but I am no expert. Perhaps folks here can recommend someone near your location that can help you get your issues sorted quickly.
Again, there is NO question that is a set-- I am pretty sure I got it used from WEVO-- they sold it to me as kind of a favor years ago. Whether it is better or worse than what you already have is hard (perhaps impossible) to assess by e-mail.
stownsen914 09-16-2019 05:01 PM
Sometimes the etching can be hard to see, especially on an old gearset that’s been around the block a few times. I had to use good light and a magnifying g glass to make out the etched numbers on a 901 gearset once. Maybe a moot point in this case
