-   -   Oxygen Sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/104013-oxygen-sensor.html)
red911 03-27-2003 12:15 PM
Oxygen Sensor
I was in the process of replacing the O2 sensor on my '83SC when I noticed that the connection that it plugs into is broken at what appears to be the porcelain or plastic, can't tell for sure. I managed to uplug the sensor but would ike to replace the part it plugs into. Does anyone know the part number or where it can be found on the PET Cd? I have searched the catalog but don't see the part. I can see the copper wire so it is not broken off.
TIA
chuckr 03-27-2003 12:25 PM
Bill,
I do not use my O2 sensor on my 83SC.I find that my car runs much better without it ! I have no cataytic converter either.I do, however live in a state that has NO emissions testing so I do not have that problem.
Carl_Boehme 05-16-2004 09:56 PM
My 81 has the same problem...
I noticed that my O2 car side connector is broken too. Did you locate a part number and or replacement part for yours?
kqw 05-16-2004 10:18 PM
Thanks for reminding me......My wrench cracked mine on reinstallation of the engine, re-attached it but he's replacing the correct fitting.
I'll repost under "O2 Sensor" the results.....
radcon 05-18-2004 08:42 AM
I'm glad that someone else posted this thread to remind me. My connector disintegrated a couple years ago when I replaced the O2 sensor and I keep forgetting to look for a new one.
