Ground cable on 77 911
Will a 911 start without the Tranny ground cable and clutch cable connected? 77 3.0 Carrera not that it probably matters.
Thanks in advance. |
Friend of Warren
It might
Kurt V No more Porsches, but a revolving number of motorcycles. |
I wonder how many parts will destruct if the starter /not sol starts looking for a ground.. what items are on that circut? cold start, thermo time sw., ign....... not an expert
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Tranny Ground.....
The clutch cable has nothing to do with your starting problem. You could start your car even with the absence of clutch cable. However, you need a good working starter, a well charged battery with good grounding to crank your engine. The engine/trans ground straps provide additional grounding.
The engine/transaxle ground strap does NOT provide additional grounding for ANYTHING!
It IS, IN FACT, the PRIMARY GROUND for the ENTIRE ENGINE ELECTRICAL SUBSYSTEM!!!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 03-27-2003 at 11:08 PM.. |
